Question about Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 200 gtl dx audio output
This rig set for 2 months .in house.when tried to put it back in service has no audio output.receives well.any ideas.also have tried about 6 mikes
    Scholar:
  • 72 Answers
Could be the jumper on the back for hooking up external speakers fell out.
Posted on Jan 29, 2008
I have a AV receiver RX-V440 Yamaha and........
The title of your question reads "I have a AV receiver RX-V440 Yamaha..." yet you say you are using the manual of an RX 1020L. I will try to provide a suitable answer for both receivers.
First, a "MON" connections on an amplifier or switching unit is normally used as a line level OUTPUT from the amplifier or switch. Line level outputs are sent to RCA connectors on other TVs or amplifiers (or switches).
"MON" should not be wired directly to the OUTPUT of anything trying to "playback". It should be connected only to things that can record or allow you to see or hear what the amplifier is outputing.
Now to answer your question:
The RX-V440 is a 6.1 channel Home Theater Receiver. If you stand behind the receiver and look at the left hand side, you will see 12 RCA connectors (2 L/R by 6 high). The top 2 connectors are labeled "CD". The next set of 2 connectors are labeled "IN/(PLAY)". The third set down from the top are labeled "OUT/(REC)".
You can connect the reel-to-reel output to either CD or IN. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select CD or IN on the RX-V440.
The RX 1020L is also a multi-channel receiver. If you stand behind the receiver and look at the left hand side near the center (top to bottom) of the receiver, you will see RCA connectors labeled "AUDIO 1" through "AUDIO 4".
You can connect the reel-to-reel output to either of these. The primary purpose for "AUDIO 3" and "AUDIO 4" is to allow you to hear component video input AV1 and AV2. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select one of the "AUDIO 1", "AUDIO 2" or whatever on the RX 1020L receiver.
Nov 21, 2017 | Audio Players & Recorders
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
I had the unit set to a second zone that ran into a splitter for four different areas of my house. The second zone is not working, how do I test to see if it is the denon unit or the splitter ?
Plug something other than Zone 2 into the splitter, say, any tape out on the Denon. Keep it simple. Play FM.
When and if THAT works go back to the manual and analyze why Zone 2 isn't working. Observe the Zone 2 Output indicator. (Page 5)
You must have a TV or other speaker-capable device that you can run Zone 2 OUT to. Try that to prove your setup works.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-789-Receivers-manual/id/23110dj895/t/2/
Page 17, 30, 31, 57,65- 68 (you get the idea).
Jun 20, 2011 | Denon AVR-789 Receiver
I have a DVD and a HD cable box going through my Yamaha RX-2400. Things worked great for past 6 months but recently started getting flickering picture and eventually picture was gone. TV says it is...
I'd investigate the intervening video-carrying cables.
Consider whether you actually NEED to route video through the receiver in the first place. Is all that extra cable and 2 extra interconnections actually doing any good? Apparently not.
In my rig, I run high-end video only to my TV and high-end audio only to my receiver. No problemos.
Feb 12, 2011 | Yamaha RX-V2400 Receiver
Trying to wire a 56 for a tristar 120. any ideas?
I think you are talking roadking 56, take the end of mike apart, you will need a 4 pin mike end,solder,steady hand,or small clip vise like I use,it takes just a little dab of solder for each wire,don,t over do it,trim each mike wire one eight inch back,slide the mike end on the cord,do not forget the plastic insulator,then solder the white (audio) to pin 1. then solder the shield and red together to pin 2,then solder the black (receive) wire to pin 3, then solder the blue (transmit) to pin 4. Then put it back together. ..hope this helps..
Mar 28, 2010 | Radio Communications
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
No audio output from a Uniden Bearcat BC-100XL Scanner
does the speaker have static when you open the squelch?
Mar 27, 2009 | Uniden Radio Communications
Audio out problem
sounds like your sound output ic may have gone.this is normally connected to a heat sink.also check that sound output settings are ok before you go further
Feb 08, 2009 | Sony STR-DB780 Receiver
No sound when using 6 channel analog inputs
2 potential issues, first make sure the dvd player audio menu setup is set correct for 5.1 outputs, not DTS or Dolby Digital bitstream, can be difficult but read the user manual under sound options if possible, second be sure the receiver is set to act as the "amplifier only setting " i.e. DVD 6 channel input, maybe EXT IN , not sure what pioneers mode is, but all you need to follow is the dvd player is outputing 6 channel signal paths, and the receiver is acting as six amps, unless of couse you are using a subwoofer line out.
Jan 25, 2009 | Pioneer VSX-D914 Receiver
I am trying to set up a SA-TX50 A/V receiver, SH-300 processor, DVD player to my Philips LCD. I also have a digital cable box, seeking assistance. Mike
1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
electech
Nov 26, 2008 | Technics SA-TX50 Receiver
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
205 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
