Question about Refrigerators
Ice forming from back of freezer to ice tray. no water, noice
Ice formed from the back of my freezer where the water comes out of the tube to the ice tray. I defrosted the ice that I could see. I never did get any true flow of water nor any ice. The ice formed again and now I don't know what to do. At this moment, I am defrosting the freezer. I do not have my manual, the refrigerator is less than 1 year old. Can you help me?
thank you
jeanette
  • jothetreeman Jan 28, 2008
    I will try your solution...will let you know. So far, I cannot get any water, will see if it gives ice.
    thnk you
  • robert samples May 11, 2010
    whats you brand and model number
    President:
  • 1,314 Answers
Girlfriend, all refrerators are self defrosting now days, this has nothing to do with your icemaker. Your's could be one of two things a frozen ice tube, or a bad ,or leaking water vavle. There are fixes for both problems. But it would help to have your modle number and brand. Because diffrent uints have diffrent problems. Please don't rate us yet til we fix your problem, give us more infromation and we will be more than gald to help you. Thank You Tech 17
Posted on Jan 28, 2008
I still need your model number and brand this soultion will not help
  • 871 Answers
Hi
always defrost your fridge at least once a month if it starts to form oce specially at the back. whenever you defrost too, try to leave it to dry at least 6 hours for the ice to really melt at the back. once theres no ice, wipe with clean damp cloth.
hope this helps
Posted on Jan 27, 2008
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
Lsc27914st/00 ice maker will not fill the tray, prior to that is the water leaked down the walls of the freezer
Hello KYMBERLY;
My name is Peter. I am a retired field service refrigeration technician.
There is a white plastic fill tube that runs from the back of your refrigerator into your freezer. This fill tube in the freezer section is open at the top. This tube goes into the ice maker fill cup on the right hand side of your ice maker. Opening and closing the freezer door - warm air gets in, forms condensate, and freezes. So, your fill tube and/or your fill tube is blocked with ice.
Remove the extra storage shelf in front of the ice maker. Using a hair dryer defrost the ice in the fill cup and fill tube. This is located on the right hand side of you icemaker.
Oct 27, 2014 | Refrigerators
Ice forming at bottom of freezer
I had a problem with Ice forming in the bottom of my freezer on my whirlpool side by side freezer-refrigerator. Turn out to be a plugged drain in the bottom of the freezer. That drain goes into a tray under the whole unit. During Defrost, condensate drops from the contents of the freezer on to the bottom of the freezer and goes through a drain tube to a pan underneath. Should that drain tube become plug and the water is left standing in the bottom of the freezer, it will turn back to ice after the defrost cycle is over. Once the drain tube is clean out, the problem goes away.
Oct 20, 2014 | Whirlpool Refrigerators
Freezer insulation
Could you fit a trace heater inside the drain tube to keep the ice from forming? Or extend the dripdown time after defrost cycle so the water doesn't accumulate? If the tech thinks the insulation has blown, it may be time to bite the bullet and replace the fridge.
Apr 18, 2014 | Freezers
Ice maker fill tube freezing
There is a possibility that the water valve isn't closing completely leaving just enough space for a drop or two of water to make its way and freeze in the tube, but more than likely the fill tube is a plastic one and little divots have formed retaining water and freezing up. These divots may not even be visible to the ***** eye. A good solution is to switch to a rubber fill tube which is less likely to have this problem.
Jun 16, 2012 | GE Refrigerators
Stainless Steel GE Profile with Bottom Freezer.
Have you had any cooling problems coincide with the ice problem? if no evidence of temperature variations, you either have a crack in the ice maker mold, causing water to drip into the ice bucket. Or you may have a bad water valve solenoid, not closing completely when the ice maker stops calling for water, overfilling ice maker into the bucket, and further down your freezer.
those are the most common problems, though other odd situations could also be a problem.
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Fan makes noise on LG lsc26905tt. defrosted and
Sounds like ice is building up near the fan blades. Try defrosting it longer to melt out all the ice and see if that helps.
Nov 09, 2009 | LG LSC26905TT Side by Side Refrigerator
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Water always inside refrigerator sometimes ice forms
LadyBlues, This is a top mount freezer. What's happening is that the drain in the freezer area is frozen over. When the unit goes into defrost, the water is running into the refrigerator area instead of going down the drain hole. You will have to remove the freezer bottom panel and then the freezer rear panel to unclog the drain hole. It will be under the evaporator in the drain tray. Use some nice hot water from the microwave and pour it into the tray until the water flows down the drain tube. This should clear up your problem. Catriver.
Jul 12, 2007 | Roper RT14DKX Top Freezer Refrigerator
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
