Question about JVC RX-8010V Receiver
JVC RX-8010V audio hook up question
I have a new tv and and HD dvd and am trying to hook it up to my receiver.
I have hooked to dvd to the TV via a hdmi cable and the TV to the receiver via a digital optical cable. When I watch TV and the signal is digital it says so on the receiver and the sound is great. When I watch a dvd the receiver says the sound is in pro logic when it should be dolby digital.
How do I get the dolby digital to come across when I watch dvds?
SOURCE: Optical audio not working
i have this problem but i dont have a cable box, if i use rca's i get sound but optical cable nothing
Posted on Oct 08, 2007
Drummernick
  • 440 Answers
SOURCE: dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Posted on Feb 03, 2008
SOURCE: jvc rx-5020v dolby digital problem
Also...If your BluRay player only has a optical output for audio you will need to swap the inputs on the JVC rx-5020v. Press the "settings" button repeatedly until "digital in" appears on the display. Now use the "adjust" up and down buttons until DVD is selected as option 2. It will look like something like: 1CD2DVD Note: this may bugger any other previous setup you have.
Posted on Apr 24, 2010
  • 1015 Answers
SOURCE: I want surround sound. How do I hook up my audio
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Posted on Jun 26, 2010
  • 11800 Answers
SOURCE: JVC receiver RX-6032 VSL is showing linear pcm,
Linear PCM is the way in which the sound is encoded in a CD, an uncompressed stereo format. It means that the audio setting is set on that system, not on Dolby Digital - what you would need to listen to 5.1 channels.
To get that back just press the INPUT DIGITAL button on the front panel repeatedly until the DOLBY DIGITAL label is displayed. If nothing happens when you do that or the signal isn't recognized as such then the defect is hardware - the audio decoder has failed and it will have to be replaced. This is a very big job that only a repair shop could do it - could, not surely can, because the replacement mainboard on which it's glued will be extremely hard to find, it's been out of production for a very long time now.
Posted on Dec 24, 2010
JVC RX-8030V, I have TV Audio hooked to back of receiver (TV Audio In) but I cannot get any sound from TV to Receiver, I can hear the speakers humm when I plug the cables in but then it goes away and no...
First of all, it is bad form and potentially dangerous to be changing cables with speaker power ON. Second, IS the unidentified TV passing audio out those jacks? Its own audio menu and controls may be between the sound and the jacks.
Oct 02, 2011 | JVC RX-8030V Receiver
I hooked up a new lg hd tv via hdmi through my digital cable box. I am not receiving true surround sound, only dolby II. I have my box digitally hooked up to the receiver and the HDTV digitally hooked up...
It's possible that the TV broadcast isn't in true surround, and is only dolby encoded.
You can try going back to the component hookups, but I am not sure that will solve your issue.
Feb 27, 2011 | Panasonic SA-HE100 Receiver
Around 4 second after power up the unit shuts down..
my jvc rx-8010v turns on and after 4 seconds it shuts down.
Jan 05, 2011 | JVC RX-8010V Receiver
Hooking up speakers via output from tv
you can do that if your TV have an audio out.....
Aug 26, 2010 | JVC RX-668V Receiver
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Hooking it up
To get the dvd working hook up to amp with a optical or coax lead to your amp digital in,set out put on dvd to give 5.1 sound,next put a phono cable from cable box to tv input on amp or sat input,now put phono cables from tv audio out to tv or other free input on amp.Set sound to prologic2 and you should have surround sound for all.
hope this helps.
CABLE GUY.
Jun 05, 2008 | JVC RX-6030V Receiver
Hook up help
i have not sound from tv only
Jan 20, 2008 | JVC RX-5020VBK Receiver
Setup configuration
Have you tried to? I would need to see a wiring block. unit to unit, labeled at each unit including the monitor. I'll bet you can do what you seek to acheive..Give me more info, I'll show you how to do it.Just a list of makes,models,serial #s. If you have all this in PDF files, shoot 'em to me.I'll draw thr lines for you.
Dec 30, 2007 | JVC RX-D301S Receiver
Jvc stereo receiver rx-5032vsl
If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
Dec 29, 2007 | Gateway FPD2275W LCD Monitor
JVC RX-8010V Receiver Logo
82 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
