Many washers have a sipping rod or bar that needs to be inserted into the unit from the rear or the bottom; this keeps the drum and balance mechanism stable while being moved. Either, the bar/rod is still in the unit and causing the noise, or it was never inserted for the move and the drum balance is off kilter and need to be physically repositioned so the drum sits well centered. Most likely, nothing is broken; just a nuisance. Goodluck, Macgivor
Motor bearing has gone and heating up so that the position/speed sensor has moved/melted causing the machine to jump about. needs new motor bearings/ new motor.
Hello Gene Frank - Typically error code DR indicates an issue with the door switch and wiring not communicating correctly or closing properly. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective, contact a professional to move forward accurately.
