Hello Larry, Download the above file from dll site, unzip it and install it. If the problem still persists then use a system utility software like RegInOut to fix corrupt registry & windows files. Hope it works for you.
I had the same problem. the only place i found that can fix this without a scan and trying to sell you something is---- microflight.com i followed the instr. and it loaded right into fms. i have vista and it did not inclued the d3drm.dll in the directx and will not load even with updates. hope this helps
To download the FMS flight sim go to this
site http://n.ethz.ch/student/mmoeller/fms/index_e.html
With windowsXP and earlier it will work fine.
BUT If you use vista you will need to also add this file to your computer "d3drm.dll"
go to http://www.driverskit.net/dll/get/494.html to download the file. Then put it in your
C:\Windows\System32 folder on your computer. It wont work until you do this. Good luck.
although it works fine with windowsXP Vista doesn't have a file it needs to run. "d3drm.dll" can be downloaded from the microsoft site or
With windowsXP and earlier it should work fine.
BUT If you use Vista you will need to add this file to your computer "d3drm.dll"
To download the European version FMS flight sim go to this site http://n.ethz.ch/student/mmoeller/fms/index_e.html with Windows XP and earlier it with work fine.
But you will need add the "d3drm.dll" file your your computer if you are using Vista. Go to http://www.driverskit.net/dll/get/494.html to download the file. Then put the d3drm.dll file in your C:\Windows\System32 folder on your computer. It wont work until you do this. Good luck.
