Question about Panasonic PT-47WX49 47" Rear Projection Television
Panasonic 42" Projection TV
I acquired this TV and opened up the back because it will not turn on. The power light comes on but there is no picture. The boards have a thick blanket of dust over them. Will that cause the TV not to work?
  • 3 more comments
  • maliplayer Jan 27, 2008
    The red light on the TV does NOT blink when you turn it on. There is no picture.
    It does click and I have the back off already. Where and what does the horizontal output and regulator transistors in the power supply look like?
    How do I test them? I have an ohm meter.
    I only one I found that started with a Q and it is Q854. Arr there more and how do you test them? I guess just as importantly, where do you find them and how much are they?
    If this helps, the serial number is mx33120777 and the number under that is ap825.
    There is another number on the back of the TV by the speaker plugs TBM2AC0441.
    The front says HDTV 1080i.
  • lifeloverfl May 11, 2010
    Have you found anymore information about the serial numbers I provided for you?
  • Panasonic Master
  • 8,617 Answers
It could, but highly unlikely. Does the power light blink series of blink then pause for a second? Let me know it may be going into shutdown and blinking a diagnosis code.
Posted on Jan 27, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jan 27, 2008
    Does it click when you push the power button? If no it may be something as simple as the relay. If it does click then you will need to check the horizontal output and regulator transistors in the power supply. That is the board on the right side looking into the back of the set.
  • Sonny Berry
    On the Right board there location numbers are Q551, Q701, Q1504, Q801 they are attached to aluminum heat sinks.
  • Sonny Berry
    Sonny Berry Jan 28, 2008
    I will research those numbers and post the info in a little while for you.
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Why won't my Panasonic 42 TCP42S30 42 Plasma TV turn on.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service
technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Panasonic 42 TCP42S30 42 Plasma TV
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Tv wont turn on
how was the pix on your tv befor it shout off if it look like a 3d piix you have bad con.v ic to see f you do open it up and look for two big ic or stk. and look for the power suppy line and unplug it now tv should come if it do come on you have bad con.v stk 392-120or 110
Dec 07, 2009 | Panasonic PT-51HX42 51" Rear Projection...
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Tv wont work
A VERY COMUN PROBLEM WITH THIS TV IS THE CONVERGENCE IC STK392-040 AND 2 RESISTOR 2.2 OHM
Apr 21, 2009 | Samsung HCN4226W 42" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
201 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
