Question about Kenmore 46462 Front Load Washer
Won't drain how do you remove the front panel, to check the pump
  • Gary Davd
    Gary Davd May 11, 2010
    post the model # from the unit please
  • 5,911 Answers
Remove the lower kick panel under the door and you should see the drain pump located directly under the wash tub. There is a screw off cap that can be removed to access the clean out trap. It is strongly recommended that you drain all residual water from the wash tub BEFORE you remove the drain pump cap, or you will have about a gallon of water to clean up. The residual water can easily be removed with the use of a wet/dry shop vac. Just remove the drain hose from the standpipe and pull a vacuum through the line with the shop vac. This will save you time later in clean up. If you do not have a shop vac, grab some old towels and place them under and around the drain pump. This will help in controlling the amount of water spill.
PS This residual water is normal in washing machines and should not be considered a problem unless the water is visible in the tub. Residual water generally sits between the outer tub and wash basket in the drain lines. This is truw with top loaders as well. Most front loaders will start a brief drain cycle at the beginning of the wash cycle to get rid of this residual standing water to prevent stagnant water from getting on your clothes. Just thought you might like to know...
I hope this helps you.
Posted on Jan 28, 2008
We had same problem we took off the lower panel and cleaned out the drain pump. it was LOADED with quaters, dimes, nickles, pennies, screws, nails, drill bits pencils...you name it it was there.
all fixed now!!
Posted on Jun 21, 2009
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
Washing machine won't drain
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump if nothing is found inside. If no noise is heard check the pump for power. To do this remove the wire connectors and connect a voltmeter turn to a drain cycle, refer to tech sheet or service manual for proper voltage reading, usually any voltage would probally indicate a faulty pump. If no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there are no obstructions. Check your hoes drain, if it is a slow drain this can cause your washer to not properly drain.
Sep 25, 2012 | Estate ETW4100SQ Top Load Washer
Whirlpool Washing Machine won't drain after pump is cleaned and there are no blockages
see the causes and remedies:God bless you
Drain Pump Filter
Drain Pump
Hoses
Jul 18, 2012 | Whirlpool Washing Machines
Won't drain after rinse cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 14, 2011 | Maytag Dishwasher
My 665 won't drain. Any idea what the issue is?
Hi
Daniel
Aug 09, 2011 | Dishwashers
My kenmore ultra dishwasher won't drain. how do i go about checking and repairing it?
Hi
Daniel
Aug 03, 2011 | Dishwashers
Won't spin and drain
Hello.
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage,
Good luck,i hope this helps
Gene
Aug 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Maytag dishwasher MDBH985AWS1 won't drain
Hi
Daniel
Jun 19, 2011 | Maytag Dishwasher
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
Washing machine won''t drain
HI thanks for your questionOn your washer theres a electric pump sometimes foreign objects get caught in pump remove front panel . Using a blade screwdriver insert between top & front panel about 2 inches from corner .The front should now come off .The pump is on the left side . Disconnect pomer If your washer is full of water now put drain hose on floor or in bucket to drain water . Now remove hoses from pump & clean reinstal . Thanks for your question The appliance doc
Sep 06, 2008 | GE WHRE5260E Top Load Washer
Kenmore 46462 Front Load Washer Logo
163 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
