Question about HP LaserJet 3055 All-In-One Printer
Hp laserjet scanning problem
My laserjet software won't load properly whereas it once had been. Also I am unable to scan.
  • fbedell Jan 27, 2008
    Well therein lies the problem. I can't get the software to reload.
    Problem Solver:
  • 5 Answers
Reinstall the software for your printer mite resolve the probem.
Good Luck
Posted on Jan 27, 2008
Only scanner problem , horizontal lines appeared during scanning
No PC model stated
no OS stated (opr. system) windows 10?
we can not help you, ever lacking key facts
why not go to your HP support page and load all software
Related to Laserjet 3050
here
https://support.hp.com/us-en/drivers/selfservice/hp-laserjet-3050-all-in-one-printer/1140783/model/1140778
Aug 06, 2017 | HP LaserJet 3050 All-In-One Printer
II downloaded the software for HP PSC 1100 all in one printer. I can print but it won't scan.
Use product no to down load the full feature drivers, check OS support also..
Oct 05, 2011 | HP LaserJet 1100 Printer
I have an HP Laserjet CM1015 Priner/scanner and an HP pavillion running Windows Vista. When I try to scan anything it says an error occured communicating with scanning device and check it is connected...
I had this too on my Vista. I re-installed the original software that came with the printer and the scanner then worked OK. My problem was always triggered when HP automatically downloaded 'updated' software, so I would disable the update feature as it only causes problems!!
Hope this works for you.
CK39
Dec 17, 2010 | HP Color LaserJet CM1015 Printer
Unable to scan on HP Laserjet 3055 on Windows XP
Sounds like a software issue - U might try contacting HP but do not hold your breath. If machine is out of warranty they want nothing to do with you and will refer you to some forum or whatever. Or they might tell you to get a new scanner compatible with a newer OS.
Jul 02, 2017 | HP LaserJet 3050 Printer
I have a HP LaserJet 3055. I bought it when I was using XP but I now have a new computer using Vista. I have downloaded and installed from HP the installation setup program for Vista - followed all the...
As i understand that you u r able to print and copy fine which ensure that there is no issue with the connectivity and scanning device.
However next troubleshooting comes in picture is software as per you have mentioned that yoiu have downloaded and installed the complete software couple of times still the issue persists.
In that case we need to Programn Scan to option in the printer software and on your all in one.
HP LaserJet 3050, 3052, 3055, 3390 and 3392 AiO Printer series - How to Program the Scan To Button and Create New Destinations
Information
The Scan To button must be programmed before it can get used. However, some destinations are programmed by default if the all-in-one is directly connected to the computer.
Details
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above step
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Dec 21, 2008 | HP LaserJet 3055 All-In-One Printer
Scanning not happening in Hp lasejet 2840 in windows vista
check to see if that printer requires direct plug into wall socket. and did that printer driver come on cd or did you get it from www.hp.com?
Dec 12, 2008 | HP LaserJet 2840 Printer
Hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Sep 25, 2008 | HP Laserjet M1319F Laser Multifunction...
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
SAM ANDERSON
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
Scanning Problem
first of all uninstall the software completely,reboot the system,install thesoftware n connect the the printer only when asked by the software
Jan 27, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
