Question about Watches
Adjusting the watch band on a Relic Adjusta Link Watch
The manual says it's easy to remove a link from this watch, but the accompanying diagram is so small and confusing that I need help..I do have some really small tools to work with, just need help on the how to.
  • 4 more comments
  • Bill Lpc Feb 19, 2008
    I need to remove some links to adjust the size on watch band for Casio EFA119BK
  • Anonymous Mar 07, 2008
    Can't understand the instructions, which are too small and very unspecific.
  • Anonymous Sep 18, 2008
    i need to adjust the link on the watch band have not been lucky to get it
  • Anonymous Oct 12, 2008
    yup the diagram is stupid, small, and not even accurate
  • cowtrails Dec 14, 2008
    same problem. any solutions? It woudl be nice to be able to wear the thing.
  • brodavid Mar 23, 2009
    I have lost the extra links that came with my watch. Is there anywhere to purchase replacement links.
Have heard to call relic 1 800 842 8621 and they will send up to two links i think with no charge just shipping
Posted on Mar 10, 2010
Set the date on my new Relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Mar 22, 2010 | Relic watch
How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Jan 09, 2010 | Relic Watches
How do you remove links from a Relic watch?
The ladies Relic used two different link systems. The easiest is the easy link system. This is a series of links that are put together with clasps. Simply undo the clasp of the number of links to remove. Its like a series of buckles. The second is a cotter pin or tension pin. You will need to push the pins out from the right end with a narrow punch. To tell the right end of a cotter pin look for the split at one end that makes it look like a screw. The opposite end will be smooth. The smooth end is the end you place your punch on and push the cotter pin out. To tell the right end of the tension pin look for the end that looks the snuggest and possibly has a dimple. The opposite end will look smaller in diameter. The smaller end is where you will place your punch to push out the pin.
Although this can be easy i always recommend going to a qualified watch maker/technician to insure you do not damage the band when removing the link.
Sep 21, 2009 | Relic watch
How to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Sep 18, 2009 | Relic 0504648FA
How to adjust watch band on relic steel watch
OK basically there must be an element that you can push out in the direction of the arrow. Either there is a very thin pin (like a needle) that you can push out with a blunt sewing needle (break the tip), or there is a more sophisticated system as it is shown under the following link:
How to remove links from a watch strap
Cheers
Critter
Dec 26, 2008 | Watches
Relic Watch Band Removal
If there are holes where the band connects to the watch and you are unable to push the spring bar out. There may be a bar connecting the band to the watch. Those are harder to push out.You might have to use a tool & hammer it with a gavel. Hope this helps
Mar 04, 2008 | Watches
Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Feb 14, 2008 | Relic 0504648FA
Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Nov 05, 2007 | Relic 0504648FA
Watches Logo
1,131 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
