Question about Nike Triax CV10 Wrist Watch
Nike triax watch
My baclight stays on after i replace the battery. I have tried resetting everything by holding down all the buttons at the same time and the light remains on. I know this is killing my battery as they only last a few hours. Please help
I cannot set my time or date as well as use any of the buttons, the only time my watch responds to pushing the buttons is when i press all four at once, which resets it to jan 1st 12:00 and i still cannot push any other buttons
Posted on Feb 29, 2008
Sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
GOOD LUCK
Posted on Feb 17, 2008
  • sthomas193 Jun 25, 2008
    If the watch only responds to the reset function (pressing all 4 button simultaneously) the movement is bad. If out of warranty, pitch it. If in warranty assuming a Nike watch contact:
    Parsec Enterprises, Inc.
    7501 North Harker Drive
    Peoria, IL 61615
    Typical turnaround time in-house is 7-10 working days, once payment has
    been received or the repair has been determined a warranty coverage.
    Thanks for your inquiry.
    Authorized Service Center for Nike
    1-800-359-2508
    Mon-Fri
    8am-5pm CST
How to reset time
Diplodocs - CASIO: 1506 references - Your user manual immediately available! Your CASIO has four push button and one for winding button. the first button has mark of LIGHT , the below button is MODE ,,upper right START/STOP,,, lower is LAP/RESET. the center button is what they called it a CROWN to set crown is just pull it and you can set the hour and minute. the LIGHT button is the set button also, just press it for 15 seconds if dial flashes, then go to MODE button and choose what going to set, the START/STOP -- LAP/RESET is the scroll button you going up and down the number or on /off ,some model of Casio Edifice, the set is in the MODE button just press it long and if flashes it ok. and follow procedure what i said before. setting cannot damage the watch. Feel free to ask question regarding your to watch so i can assist.. Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Casio Edifice EFA109-7AV Wrist Watch
I received my suunto t3d black watch yesterday and accidentally set the contrast too high and it saved. I've tried everything but can't seem to find the setting to fix it. I've even removed the...
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Aug 13, 2011 | Watches
Hello ,,, I changed the battery in my Timex Indiglo and now just the light is working but not the minute hand or time hands. How do I fix this I have tried two batteries already?
Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
Jul 23, 2010 | Timex 27191 Wristwatch
After replacing battery, the watch does not
I found and pressed the reset button with a tiny screw driver. After about 10 attempts, I pressed the function side button and found that date and time displayed temporarily while holding button down.
Finally after more reset attempts, the time did display.
Nov 25, 2009 | Timex Expedition 84601 Wristwatch
GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
Nov 29, 2008 | Nike Triax Fly WK0006 009 Watch
Bijoux Terner Sport watch RO616F
I got one of these on a cruise, and I had the same issue, and searched on the web just now (7/26/08 9:20pm) and could not find an answer.....so, I just sat here for a few minutes to push all the buttons...
Mine has 4 buttons at the 2, 4,8,10 positions....corresponding to "start", "reset", "mode", "light"
Hold down the "start", then while holding it down, push the "reset" button.....voila!
Jul 21, 2008 | Cerruti Watches
WATCH SET
For Timex sport 1440 indiglo
page through mode (bottom button ) til u get to time
When time shows up hold down lap/rst button on right untilset starts flashing
use mode buton at bottom to find element you want to change (let's stay minutes)
put st./stop button at top to get to number (minute) you want
hit lap/rst to get out.
Mar 11, 2008 | Watches
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Women's Timex Rush Sportwatch
Try holding all of the buttons down at the same time and then releasing them. This should reset the watch. If that does not work, then you need to take the back cover off again and briefly create a short (with a metal screw driver for example) between the battery and the 'brass' casing. Hope this works for you!
Aug 25, 2007 | Timex Rush Sports Watch
Nike Triax CV10 Wrist Watch Logo
285 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Nike Watch Expert? Answer questions, earn points and help others
