Gatway 420GR when i go into control pannal then to sound and devices and go to the audio and voice setup and change the sound recording to realtalk audio rear and put the midia centre device on and then go to the voice and change change the front to back save all close the pannal then reopen all the settings go back to the beginng they wont stay on what i set them at and the speaker that supoostto be on the task bar close to the bottom clock does not come on all drivers are up tpo date ?
  • 1,067 Answers
Hi what are u tryoing to do 1st i was gona join u in achat but was beatin to it i can help
Posted on Jan 27, 2008
  • nick helpap
    nick helpap Jan 27, 2008
    u wann record sumthign ? and reltch dont allow changes but what else u trying to do when u change the rear to sumthign else u can just add on more in auido panel by the start and u can tell itto make icon on desktoip start cheaking abox
No voice detect in microphone & speaker
  • Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the Audio Drivers. Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel. Scroll to find, "Hardware and Sound, select "Audio Devices and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" the (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced), “not recommended!” In the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: “Click the "OK" to all change; 'Save,' and apply!” before exiting. “Rating the solution is appreciated, thanks”
Apr 24, 2010 | Compaq Creative Sound Blaster PCI 128...
Im trying to play music through my sound card and talk on the mic in paltalk i got SB1090 and it sitll dosnt work
try going to Start>Control Panel>Sounds,Speech, and other Audio Devices>Sounds and Audio Devices>click on Voice tab>go to Voice Recording,Default Device and change it to your current device.
Oct 15, 2009 | Creative Labs Sound Blaster Live! 5.1...
How do i connect an external microphone to my philips freevents x55. only the built in microphone is working. an externally connected mic does not over-ride the internal one?
Your default recording device is still set on the built-in mic.
In Microsoft XP...
Choose Start > Settings > Control Panel and double-click the Sounds and Audio Devices tab
Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
In Vista, choose Start> Control Panel > Sounds and click on the Recording tab.
In both instances, choose your external mic as the default.
Windows XP 1 Choose Start > Settings > Control Panel and double-click theSounds and Audio Devicescontrol panel.
2 Select the Voice tab and choose the the appropriate item in the Voice recording Default device pop-up menu.
Oct 04, 2009 | Computers & Internet
Why i cant talk in headphone i can hear the voice in computer. i installed nymgo talking internationally i can herta the voice but i cant speak the speaker placed in my mouth does not have voice
Click on start->control panel->sounds and audio devices->audio tab->under sound recording click on volume tab and uncheck mute all and anyother mute.
Oct 03, 2009 | Audio Players & Recorders
Sound problem:headphone mike does not work properly
when i am catting with my friend i can't hear anything but he can hear my voice..
Apr 25, 2009 | Creative Labs Sound Blaster Live! 5.1...
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
Cannot render audio capture stream
On the "Audio Settings" in the Life View software, at the "Audio Input Source" on the drop down arrow, select "None". This settings will use the internal PCI Bus for listening and recording TV. The audio loop back cable in this case is not needed anymore.
Dec 06, 2008 | LifeView FlyVideo 2000 / FM (701013821030)...
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Gatway 420GR
format pc setup your sound and other.........
Jan 27, 2008 | Gateway GT4022 PC Desktop
My mic doesnt work
to put that in cam microphone working, you need to see on audio settings properties and change the "recording device" to usb audio device, instaid of the soundcard as is. That means that the sound recording will be from the cam's microphone.
The steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB AUDIO DEVICE and then OK
4- In the remaining volume control window, select MICROPHONE and then close all the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Jan 23, 2008 | Logitech QuickCam Fusion Webcam
74 people viewed this question
