Question about Toshiba Portege 3490CT Notebook
Trying to Rebuilt my Toshiba Portege 3490 Labtop
I have a problem on this PC. I Tried installing xp, 2000, and even 98.. but nothing seems to work. It pops up on windows 2000 with "INACCESSIBLE_BOOT_DEVICE" It suggest stuff like check for hard drive corruption and stuff like that.. it is an irritating problem.. a suggestion i heard was check the inside like the HARD DRIVE..
    Sergeant:
  • 226 Answers
Check the ide cables or sata cable if it is propely installed then make sure that your drive is master in jumper settings. then try to install xp.
Posted on Jan 27, 2008
I know nightmare ned wont work with windows 7 which is what i have so i installed it on my windows virtual pc in xp mode and the install went fine. But when i try to play it nothing happens. I click on the...
Depending on how old this game is, ( like made before 2002) It is out of date to current windows systems, you would need something like windows 2000 or windows 98 for the game to work
Good Luck I hope this helps :D
Jun 13, 2011 | Disney Interactive Nightmare Ned for...
Can't boot with Cd-Rom unable to install windows XP
Well, maybe I can try, thus in your bios setting you can boot using usb cdrom? Or maybe its time to change your cdrom drive already. If you can borrow a good spare cdrom. Take this in for the meantime in exchange for your installed cdrom. Maybe your cdrom drive is faulty. Then if this is ok, it is now easy for you to get on.
Second option, you can take out your harddrive prime it, then have a partition (say d:\) with a copy of full copy of xp installer, and other important installer just have it foldered. Then I assume you can boot using a floppy drive with win98 rescue disk. After booting goto harddrive partition with xp installer. then click setup and set it up in c:\ . Then your go other software, installed it manually.
I do this coz it much faster to installed using harddrive and also it is only in xp.
Hope this helps. comments if I miss something.
May 05, 2009 | Microsoft Windows XP Home Edition
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
D-Link Airplus DWL-G520 problem with windows server 2003
D-Link Airplus DWL-G520 on PCI drivers do NOT support Server 2003. It will only support these OS
Windows 98/Me/2000/XP
If you boot your XP is it still working ?
Mar 15, 2009 | Intel D101GGC Motherboard
I try to boot my computer from a windows 98 disc, but it won't lo
Hi matthewbugbe,
I think what that means is it does not recognize your hard drive. If you are trying to install Windows 98 you should format your drive first.
Mar 08, 2009 | Microsoft Windows 2000 for PC
DEll Latitude c610 laptop computer
put in the windows 2000 or xp disk
98 is not supported by microsoft , youll have many problems online
but you need to format the hard drive , 20 gb is good
with the windows xp cd boot from it
you will see just one letter drive if more delete them and format just one drive, you can use the quick format , so the windows xp files will go on after that, but youll have 30 day trial
Jan 27, 2009 | Dell Latitude C610 Notebook
Super scattergories
Microsoft Windows 98 was an operating system used on a majority of personal computers from 1998 to 2000. Because of this, there are a variety of games available to play on Windows 98, but are incompatible with later versions of Windows. If you have Windows XP or higher, you have access to a "Compatibility Mode" that allows your computer to play those games. Activating compatibility mode is a simple procedure.
Right-click the file that you usually click on when you are trying to start a game.
Select the "Properties" option in the drop-down menu.
Select the "Compatibility" tab, then check the "Windows 98" box.
Select the proper video mode for your game under "Display Settings."
Select the "Apply" button to save your settings, and select "OK."
Double-click on your game's file to begin playing the game.
Nov 09, 2008 | Hasbro Interactive Super Scattergories for...
Im plugging my flash drive into the usb and nothing is coming up. this one works in other computers but not this one
For starters, what is the operating system of this computer?
Windows XP will recognise flash drives, 2000 seems to recognise some but if you have 95, 98 or Me you need to install a driver for the drive. The manufacturer of the drive may not even supply one.
Sep 28, 2008 | Computers & Internet
Plz help me ..regarding uninstallation
go to start then select run and type msconfig the hit enter key
when a window pop up click on the boot.ini then delete the boot partition where windows 98 located then restart your unit
Aug 14, 2008 | Microsoft Computers & Internet
I cant install windows in my computer
Have you tried another installation CD?
Have you performed a HD format with a Windows 98 boot disk?
Nov 28, 2007 | Compaq Armada E500 Notebook
Toshiba Portege 3490CT Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
