Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spin Cycle Makes a loud clicking noise when reaching a spin cycle. It does appear to still be spinning. Water does drain, but I dont think as quickly on either.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 28, 2008
After washing it makes loud noise & won't spin or drain
You shoul inspekt water outlet on the bottom of the drum. There is mabye something inthere.
Dec 02, 2017 | Washing Machines
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Oct 12, 2009 | Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Jan 24, 2009 | Maytag Performa PAV2200
Loud noise in spin cycle
Most leaks are associatd with your drain pumps although it can leak from the tub. If its the tube the seals in it are worn if it the drain pump - the first point to check is where the drain hose connecs to the pump otherwise you may need to replace the drain pump
The noise - if its what i am thinking of starts just as the spin cycle stsrts and just as it finishes - usually a clutch problem - worn - parts need to be changed.
Regards
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
My frigidaire washer want spin
Sounds like the lid switch may have went bad. It has an independent drain pump so will still drain water. Give that a try and see. Godd Luck!!! Jim
Sep 14, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
