FixYa.com
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
V7 Television has no picture after power bump (by 3 users)
posted by willyam on Jan 27, 2008
Can you assist me with this problem?  I believe that I may have to reset but the manual does not provide me with an answer or method of doing so.  Would you be able to assist me?
Comment by willyam, posted on Jan 28, 2008
Sorry but it didn't work. I still don't have a picture.  Could there be another method of resetting?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Disteck Tele, posted on Jun 09, 2008
My Disteck Plasma television makes a click sound when i turn it on. It gives no pictures nor sound through speakers. What could be the problem??
Comment by red lopez, posted on Feb 06, 2008
i had disconected tv to move furniture around. and now i have no picture or sound. red light is on but when i hit the power botton on top of tv light changes to green for about 2 to 3 seconds and goes back to red. i called protron they add vice to disconect from outlet for 30 to 40 minutes so tv can reset. i left tv unplug for a few hours and still no pictures or sound.
Best Solution
posted on Jan 27, 2008
Thanks for Trying (70)
mikeuk
Rank:Master Master
Rating: 84%, 14 votes
Is the V7 made by Elect? If so, hold the setup or menu key on the remote, then at the same time hold in the setup or menu button on the TV. Wait for 10 seconds and the engineers menu will display. Select Factory reset and power down your TV.
Comment by mikeuk, posted on Jan 28, 2008
Sorry, but that's the only way - if you don't have a picture, you won't be able to see the menu with the engineers options. It sounds very much as if you will need to take it to a TV repair shop and have the boards tested - it looks like a power short. Don't worry though, as it's rare for the panel itself to be damaged after a power bump and that's the most expensive thing in a set. I don't know where you live, but even a whole board shouldn't cost more than $100 to replace..
Rating Locked! (?) willyam has rated this solution as Thanks for Trying
This Problem Also Relates To: Panasonic TH-42PX60U Television Panasonic VIERA TH-65PV500 65 in. Plasma Television Panasonic PT-44LCX65 Television Panasonic TH-37PD25U/P 37 in. EDTV-Ready Plasma Television Sony BRAVIA KDL-40V2500 40 in. HDTV LCD Television Sony KDF-E50A10 50 in. HDTV LCD Television Sony BRAVIA KDL-46V3000 Television
Can you Help with these Flat Panel Televisions problems?
Sony KDF-E42A10 42 in. LCD Television
Pink circle or highlight on...
You can actually see the pink... Answer This...
Philips 42PF9630A 42 in. Plasma Television
philips s lc4.3e 32pf532-10
there is no sound Answer This...
Philips 37PF7320A 37 in. HDTV-Ready LCD...
Philips 37PF7320A/37 won't turn...
Last night I had been watching... Answer This...
remote control range not...
I bought a sony bravia 32S3000... Answer This...
Sharp Aquos LC-46D62U 46 in. HDTV LCD...
Vertical 1cm-wide...
My 46" Aquos has been... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
