Question about LG WM-2277HW Front Load Washer
LG WM 1832CW
The stator with the sensor assembly had already been changed on myLG WM 1832CW washer, however the rotor has many magnets, and the part of one magnet is slightly broken, could that cause the washer not to spin and give the LE code?
If your getting LE code on your LG washer check if your hot and cold water is hooked up right
Posted on Jan 28, 2008
My LG intellowasher 7kg WM -131 50 FB is not washing and keeps flashing 5E
If the washer won't agitate the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Nov 21, 2014 | LG Washing Machines
The drum doesn't want to vibrate
If the washer won't agitate or spin, then the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects
Oct 21, 2014 | LG WM-1832C Front Load Washer
Drum willnot move on start.it just thumps
If the washer won't agitate the stator assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Sep 28, 2014 | LG WM2487H Front Load Washer
8 YEAR OLD LG FRONT LOAD WASHER WONT SPIN OR DRAIN
If the washer won't spin the stator or rotor assemblies at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects
Aug 29, 2014 | LG WM1814CW Front Load Washer
LG Tromm WM2277HW drum was noisy, then wobbly and now has stopped spinning
Remove back cover and check for a loose nut that holds the rotor. you may have to replace the rotor( is the cover that holds the magnets). Not the stator (which is the motor.)
Apr 28, 2014 | LG WM-2277HW Front Load Washer
Where is the hall sensor
A hall sensor is a magnetic pickup sensor that picks up magnetic pulses caused by a rotor that is bolted to the spinner shaft in back of unit. remove back access panel and motor rotor is facing you now. take bolt off of rotor and slide off. you should be able to see hall sensor under stator. remove bolts on stator to access hall sensor.
Apr 17, 2014 | LG WM2101HW 4.0 cu.ft. Washer
Need to change stator and rotor assembly in WM2688H*MA
The stator is stationary mounted to the outer tub the rotor attaches to the spindle of the basket which is a shaft that goes thru a bearing to get a definitive answer remove the back panel remove the rotor turn the center bolt till it loosens keep going as this will back the rotor off the stator you will have to pull with a little effort strong magnets to get it off now try to spin the basket by hand if stiff you have a bad tub bearing.
Apr 02, 2014 | LG Washing Machines
Why does my lg front loader washer wm-1832cw sometimes give anle code and sometimes works
you have either a hall senser /stator/or main board/problem.... may even be a voltage issue. check your recepticle see if its good. easy first check plug to see if its been arking on the plungs
Jun 03, 2011 | LG WM-1832C Front Load Washer
Lg tromm
The bearing is pressed in in the factory and is only available as a rear tub assembly. They claim to have extremely tight tolerances to prevent wear and unbalance. Check your owner's manual there may be an extended warranty on the rear half of the tub.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
551 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
