Question about Xerox WorkCentre PE16 All-In-One Laser Printer
PE16 xerox How can i open the xerox PE16 scanner so i can clean it plse advise
    President:
  • 2,072 Answers
You have to remove the 4 screws from the back of the machine, and remove the back cover.
Then remove both side covers. They are on with plastic tabs on the sides. They will with some work pop off.
Be sure NOT to break the wire to the speaker when removing the covers.
You next have to remove the connectors from the document feeder and scanner located on the right side of the machine looking from the rear. Also unscrew the ground wire.
Remove 2 screws from the back portion of where the scanner is connected to the frame, just above the fuser.
Slowly remove the scanner/feeder assembly. They interlock into the front of the machine.
Remove the document feeder from the scanner. Just slides out.
Lay the scanner glass side down.
Remove the screws holding the controle consol on, remove and unplug the consol. Then take the screws out of the scanner, from the top, that hold the scanner together. There are a couple of tabs you need to release to seperate the upper and lower scanner.
Then you have to carefully pop the tabs in the scanner head to release the lamp assembly from the CCD assembly to clean the mirrors, being very careful not to break one of the mirrors in the process of popping the tabs to realease the lamp bracket assembly.
Clean with a soft cloth and glass cleaner, then repeat the procedure in reverse to put it back together.
Take your time and be sure you get everything plugged back in.
You just about take the machine down to nothing to clean the scanner.
Not difficult, But please take your time and make notes, or careful mentally make notes so reassambly is easier.
Hope this helps.
Posted on Jan 28, 2008
How to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
May 20, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
How to unlock scanner in xerox pe220 printer
u have to move latch near scanner unit to unlock position
Dec 14, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Ow to change resolution in xerox workcenter pe16 scanner
resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
May 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Photocopies are very faint on one side
The scanner mirrors are dirty.
You can try doing a shading adjustment . You press menu #1934 to enter tech mode. Then in menus under maintenance go to shading adjustment, place 5 sheets of paper on the glass and run the shading adjustment. That may help.
But the problem is the mirrors are hazy and in need of cleaning. The rear, both side covers must be removed. Then 2 screws on the back of the scanner must be removed , and the connectors unpluged from the main board. There is also one green ground wire that is attached to the frame from the scanner.
Once the scanner is removed, you have I believe 4 screws to remove and the controle panel.
You have to be very careful opening the scan head under the lamp. It is just held together with plastic tabs. Under the lamp are the mirror and lens, that must be cleaned to get your copy quality back to mormal
Apr 01, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox workcentre pe16
Remove the back cover. And looking from the back, remove the right side cover. There is a white ribbon cable and one connector with mostly red wires, remove and reseat those. Return power to the machine and see if it comes on.
If not, then remove the right side cover, the 2 screws that fasten the scanner to the frame, remove the scanner and then the controle consol, ( display.) then unplug all the connectors on the display and reconnect them.
It the display still does not work after reseating all the connectors, the display itself is defective.
Mar 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox PE16 Workcenter
if you print from a printer do you get the blank like?
if Yes, then you may have some dead LED's on the scanner (this will need replacement)
if No, then look at your scanner (small thin glass strip that reads the paper when being copied) and clean it. 9 times out of 10 there is some white-out or toner stuck to it, clean it and that should fix that.
hope this helps with the white line
thanks for rating
Jan 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Scanned images include darker strips
Hi, Clean the small scannerglass. every dot on the small slass becomes a stripe.
Mar 03, 2007 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
387 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
