Question about RCA P46810LV 46" Rear Projection Television
Toshiba TZ55X71 According to the repairman, my TV has major damage to the circuit boards. Is it worth repairing?
  • 145 Answers
It really depends. If the board is cracked or broken then I would say no, if it is something more simply repairable then sure, call a repair shop to get an estimate then go from there. With the price of TV's these days it may not be cheaper to replace, but then again your current one may not even be repairable.
Posted on Jan 27, 2008
Why dose my panasonic pt 52lcx66 tv turns on after 1 min it blinks green and all images disapears ?
major problem with the picture circuit. could need soldering only or components. not a major problem for repair shop but tv probably not worth the repair. time for a flatscreen, same price as repair of this one.
May 12, 2014 | Panasonic Televison & Video
The tv works but without picture
YOU HAVE A INTERNAL TV PROBLEM ON A ELECTRICAL CIRCUIT BOARD. SOUND WILL COME THRU BUT NO PICTURE. IT WILL NEED TO BE SERVICED BY A TV REPAIRMAN. ON CERTAIN TVS IT MAY BE AS SIMPLE AS A CONNECTION CABLE FROM THE CIRCUIT BOARD TO THE TV SCREEN, BUT IT IS STILL A TV SERVICE REPAIR FIX. - SORRY
Feb 20, 2011 | Home
We just purchased a 50" PLasma Samsung Flat Screen TV withing the last month. As my husband was hanging something it fell on it and cracked the screen. We still get a picture but it has a circle about...
It a lost cause can't repair Screen panels,only replaced them.The screen panels are limited produced by the tvs industries.They're the only place u can buy it from,they'll charge the screen panels same as a new tv.Sorry ur tv it not worth as a whole tv anymore,only as salvage electronic circuit boards for parts now.This is a new tv right,call Samsung,talk to them,buy a new tv directly from them.They'll give u some credits for the returning the damage tv unit with a screen panel damage to them.
Sep 09, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Hitachi 60" Ultravision TV - bad green tube that is leaking
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dan
Dec 09, 2009 | Hitachi Televison & Video
I have a 42 inch Vizio tv and moved it to the bedroom from the den. I hooked it up to the cable (sat) like it was in the Den and it blew a cable line out. The socket was updated but now the tv plug got hot...
'probably the main transformer, bridge rectifiers, fuses, on the tv power circuit are damaged......along with some other components. Depending on the level of damage the board may, or may not be repairable. If so you may want to get a tv technician to install a replacement power board.
Nov 02, 2009 | Vizio L32 32 in. LCD HDTV
My 62 inch mitsubishi tv was hit by lighting
Try to find a local repair centre & ask if they can give you an estimate on the cost to repair. A lightning strike can cause either minor damage such as just an internal fuse blown or can cause severe damage which will wipe out entire circuit boards which can be a costly repair. In this case it's usually not worth repairing.
Oct 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I got a 51 inch rear projection sony and it had slight water damage...is it worth repairing?
It really depends on what component (s) are worn or burnt out. If you are unsure of which components it may be, you can get a capacitor tester and test all the capacitors in the tv, or get a quote by repair tech before making a decision. If you had major fluding, you may have faulty power supply which is worth it, or the whole board may be faulty and would not be worth repairing
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Bad Video Board
I know a company that can fix but I do not know your zip code to verify if they can do it in your area but its worth a shot www.teexp.com please do not hate me if they do not work in your area but they specialise in Mitsubishi also do not stop there look on ebay you be surprized on what you may find there.
Jul 17, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Powering on Hitachi TV
If all you hear is a click and you get no display on the screen, it sounds as though you need a repairman to come out and fix the circuit board. There are several things that cause this symptom on your set but the most common are convergenge amp failure, vertical, or power supply issues. Sometimes as simple as resoldering connections. Other times major troubleshooting and part replacement are required. The repair cost is usually between 175.00 and 375.00 hope you have a trustworthy and knowledgable repair person, good luck, Russmann.
Jul 08, 2008 | Hitachi 50FX20B 50" Rear Projection...
Vertical size
make checks on your vertical it could be getting too much voltage replace it along with some cap around that are not filtering the voltage to the ic.because it have cause damage to your vertical change all related components in that circuit also check the related circuits.you can get a schematic for your set at www.samsphotofact.com good luck
Mar 29, 2007 | Panasonic PT-51G44 51" Rear Projection...
Televison & Video Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
