Paper shredder gear is stripped.....replacements?
I have a Royal VF880 paper shredder and some of the mounting screws came lose (due to vibration, no doubt), causing one of the motor gears to become stripped and rendering the whole unit inoperable.  Any chance of getting a replacement gear?  Everything else is fine and it's easy to fix, but without that gear, it's useless.  I hate to join the throwaway society of ours!  Any ideas??
Mike spanky_velo@yahoo.com
  • dumox Jul 06, 2008
    Same problem precisely. The Royal 85x shredder jammed and the nylon or acetal gear is stripped after worm gear on the motor shaved it. At this point I would replace that plastic gear myself and reassemble to whole thing. Given the original cost and the inconvenience of the service depot it is not worth it to pay someone else but I hate to throw all that plastic and metal into landfill.
    AN
  • jwcva Jan 15, 2009
    I have the same problem on a Royal 1280x model. Took it apart to find not 1, not 2, but THREE screws had decided to leave there comfortable holes. All 3 were secuing a cage around one of the gears. I have to ask Royal - why not a dab of loc-tite on the screw threads if they are so prone to vibrate out... or is it a matter of not being tight from the start? Either way, seems to be a mfr problem.
    At any rate, I want to find out if anyone (previous posters?) has found a source for replacement gears? I suspect I have the same type gear that is stripped (two teeth) as the other posters since all other gearing is metal...
    Thanks for any input.
    Scholar:
  • 102 Answers
Best bet is Royal Customer Service at 888-261-4555
Posted on Mar 02, 2008
My Royal paper shredder model VF1700mx has stripped one of the nylon (?) gears. It looks possible to replace. Are these gears avaliable today?
you will have to contact the ,manufacturers spares or service agent for the brand but generally if a gear has stripped, it is cheaper to junk it and replace it with a new unit
Jan 24, 2017 | Royal Office Equipment & Supplies
Tried to feed to much (thickness) through ... I have done this in the past but was able to remove jammed paper by going forward and back until jam was cleared ... this time however it seems the motor just...
This is the most common problem...people put TOO MUCH paper in shredders... the VF880 has plastic gears inside...having done this a number of times you may have broken the gears or stripped the "teeth" off the gears...open it up to see what damage has been done; once you know what is broken you can contact Royal for pricing and parts at 1-800-524-0799.
Dec 11, 2010 | Royal VF880 Shredder
The shredder developed a jam. I removed the bin and the top of the shredder. I removed the shredding mech. and removed the paper material. Reassembled the shredder. Shredder starts up when paper is...
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check,...contact Royal at 1-800-524-0799 for parts assistance.
Oct 27, 2010 | Royal VF880 Shredder
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
How do I go about getting replacement plastic
For Royal parts and prices give Royal a call at 1-800-524-0799.
Feb 06, 2010 | Royal Office Equipment & Supplies
Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Oct 23, 2009 | Royal VF1000MX Shredder
Gears won't pull paper through
One of the gears has stripped teeth. I've got the same problem and am looking for a replacement.
Apr 02, 2008 | Royal 160MX Shredder
Royal 15mx
You probably have the same problem we do.....the unit vibrated some of the mounting screws loose, causing the gears to disengage slightly and then strip one of them (plastic).....hence, no movement of the shredder, even though the motor is fine.  I myself am looking to Royal for a replacement gear.  I don't want to have to buy another one and it beats throwing the whole thing out....what a waste!  Maybe they should start using some glue on the mounting bolts!
Nov 23, 2007 | Royal VF880 Shredder
3,955 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
