Question about Car Audio & Video
Wiring up an amp
We are trying to wire up our amp and sub into our renault megane but we dont seem to get anything coming out. we are not sure if its to do with the on/off switch. what should we wire the remote switch to.
  • Anonymous Feb 02, 2008
    what coloured wire is the remote wire on the stereo is it the red?
You can also plug that cable to any positive wire adding a switch of course. the only problem... don't forget it on, it will eat up your battery if left like that unless the positive power source is canceled when removing the key from the car.
Posted on Feb 02, 2008
  • 3 Answers
You must to connect remote swith wire from your CD player to amplifiers remote switch wire. It needs because when you turning player off its turning off your aplifiers power and wise versa.
Posted on Jan 27, 2008
Renault megane grande scenic live wire touched body arcing everything out no battery lights or anything what could it be checked all the fuses and there all fine
Are any lights coming on at all on your cluster?? Or is car completely out of power?? If so, you may have a main fuse or broken fuse link from your battery to main fuse box.
Feb 07, 2016 | Renault Cars & Trucks
Renault megane alarm no sound
Check your key button, or pop the hood, find the horn shaped thingy, that could be the alarm, should have a black wire and grounded terminal, make sure that wire is connected and earthed properly.
Apr 27, 2014 | 2005 Renault Megane
Wiring/sub-woofer not putting out!!
The remote wire from your head unit should be blue and there should be a wire that connects that to your amp. Make sure it is hooked up. Also, if you are using the high in put wiring up above, it shouldn't be mixed with your RCA. That wiring diagram is not needed for the subs. You should also check the gauge on you power wire that runs from the battery to the amp. If it is 4 or less it should be good if it is Copper Clad aluminum (CCA) it will put out power similar to 8 gauge copper wire. Most of the time the problem with the low output of subs is the amp wiring kit. You could have great subs and a great amp, but if the wire isn't any good it can sound like ****. Just FYI in case you weren't familiar with any of that. Always try to get pure copper wire when it comes to the power cable. You can google information about it. If you're wiring there is fine. Again, check the remote wires. Also check to see you have your amp levels turned up as well. As for the violet and violet/white. Those are referring to you speakers in your vehicle. Not your subs.
Oct 02, 2012 | Car Audio & Video
Amp worked fine one day and the next day i get nothing. the red light on the side is on but i dont get any sound. i took the subs that were wired on that amp and wired them on the other punch 800 i have...
did you check all fuses on amp and coming from battery power wire? also check the ground and rca cables connecting to the unit and make sure the remote wire (small blue wire) didnt come lose thats usualy a sign for the red light
Mar 26, 2011 | Rockford Fosgate Punch 800a2 Car Audio...
I dont have an owners manual for my renault megane w reg, the rear wiper is not working & there is no space in fuse box for a fuse, is there somewhere else for a fuse for this
Rear wiper morors are notorious for developing faults, Access the motor wiring and test for power. I don't think there is a designated fuse for the rear wiper but a call to Renault dealet will clarify. The less frequent use and water ingress is top of suspect problems. Good luck
Apr 05, 2010 | 2000 Renault 181
Wont start
first check upc which is next to battery. check block plugs for water and corrosion if there is you will need to change etc check fuses on battery positive terminal.if these are all ok. you will need to check wiring for corrosion from upc to ecu. normally orange wire in loom is 5v wire to power up ecu.
Feb 19, 2010 | 2004 Renault Sportwagon
Dashboard lights
Their wiring can be something .The circuit boards short out and the lights on the right front where on with the left rear lights.
Jul 01, 2008 | Renault Sport Cars & Trucks
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
