Question about Quadrant MB-AT-5MVP3 Motherboard
Mother board i have intel kob810 dsmt mother board it is working since 4years .at last week i found that the board is nt working properly. i consult an Hardware engineer he cheked everything and told me that the board have chipset problem that cannot be repaired .so my question is could the board will be repaired can i change the chipsets.
    Novelist:
  • 86 Answers
Changing the chipset is NOT feasible; you'd have a VERY difficult time finding the proper chips to replace the damaged ones, and removing / replacing a surface-mounted chipset is usually done with specialized equipment. The costs of repair would be prohibitive...
The best advice I can give you is to obtain another motherboard, unless you have unlimited funds available, and can wait while the defective board is being repaired, all of which requires that you first obtain a replacement chipset, which would be difficult, given the age of your motherboard...
Wish I had better news for you, but even if you did replace the defective chip(S) on that motherboard, it is still an old board, and the odds are that some other component will fail before too long, which would make all of your efforts getting the m'board repaired just a huge waste of time and money.
Best of luck to you; let us know what you decide to do...
Posted on Jan 27, 2008
    Genius:
  • 1,554 Answers
No the chipset is something that not even an experienced tech with the proper tools want to try.
you will need the same replacement board for windows to be happy. if you change board models you'll have to reload windows.
6ya staff
SOURCE:
My name is naidu. my pc configuration is Intel Pentium 4 Processor Intel 865GV Mother Board i lost my mother board CD. i some how know that it supports Realtek AC'97 audio drivers . when i was...
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows
operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Feb 14, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have intel celeron 2.53GHZ PC...and i cant access my USB port in XP2 ....so pls tell me what i can do for this..i install 2.0 USB Drivers also...but it nt working still...so pls give me some...
I have intel celeron 2.53GHZ PC...and i cant access my USB port in XP2 ....so pls tell me what i can do for this..i install 2.0 USB Drivers also...but it nt working still...so pls give me some solustion...thank uu..
Oct 02, 2010 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Omdear sir , I bought my computer on 16th aug'2004,It icludes intel d865gbf mother board, p4 processor with 2.48 ghz clock speed . some days ago when i switched on my machine , i found there is no...
symptoms show of a hardware failure.
but did you replaced your small battery in this period and was your computer clock working fine ?if not first concider replacing your battery then consult a hardware technician
Sep 28, 2010 | Intel D865GBF Motherboard
Mother Board
if it has 2 video cards or had 2 might be disabled in bios. if not and it does not boot at all then it could be CPU Powersupply or RAM, i would start with removing RAM and see if it beeps if it does Power Supply migh be ok, put one stick of RAM back in snd see if it boots swap RAM Slots and stic around to make sure its not a RAM Problem. if still no video and just spinning fans its Trial anf error of the CPU and Power Supply i know it **** but if you have a PoSupply tester that would rule that out. if you are savy enough to remove CPU look for burnning and smell for Burn. Good Luck
Feb 24, 2010 | Intel Motherboard
Sound quality
The sound quality built in to most mother boards is not the best quality. It is a compromise. The best solution is to install a high quality sound card in an available slot.
For video quality, it is the same issue when it comes to high quality video.
Before installing the new sound card, uninstall the existing sound drivers and sound software for the built in sound as necessary. You may have to go in to the BIOS set-up and dissable the mother board's built in sound. It is best to consult the instructions for *********** board to know the details for the particular mother board. You should contact the dealer for your computer to have proper details.
Turn off the computer, and disconnect the AC cord. Open the case, and install the new sound card according to the instructions that come with it.
When the computer re-starts, it should tell you that it found new hardware. Go through the installation procedure. There will be drivers and some software and drivers that must be installed.
If you are not used to this type of procedure, it would be best for you to take the computer to a computer service place and have them do the installation for you.
Jerry G.
Sep 13, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Audio driver
Go to hardware profile under my computer, or forget windows altogether, LINUX is free, easy, fast, and won't take years off your life.
Jul 30, 2008 | Computers & Internet
Display
I have Intel Jetway 945 Mother Board, I checked the Processer and Ram, And SMPS it is working properly, but I am facing display problem.
Oct 29, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Open Questions:
Outlook MAil Contact NuMbER {?}{1?.855?.536*?*5666}#[email protected] COLORADO call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 11, 2019 | Best Computers & Internet
Outlook MAil Toll {1^855^&536^&5666}#[email protected] Free NuMbER HELP DESK call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
See all Quadrant MB-AT-5MVP3 Motherboard Questions
Quadrant MB-AT-5MVP3 Motherboard Logo
116 people viewed this question
Top Quadrant Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Quadrant Computer and Internet Expert? Answer questions, earn points and help others
