Overload When I turn on receiver, it only works for a few seconds. Then it stops, and "overload" comes on the information area. This occurred after a power outagoe where there was some dimming before the power when out.
  • 112 Answers
Sounds like a voltage regulator or other componant has failed internally. What is the make / model?
Posted on Feb 06, 2008
Lo warning comes on when i try to sew. Waited 15 secs did not work. Cannot sew.
It sounds like a machine overload. Rather than just turning it off for a few seconds, turn it off and clear out the lint from the feed dogs and the traces. That should take sufficient time to reset and you'll avoid another overload.
Jun 30, 2015 | Janome Magnolia 7330 Sewing Machine
When I turn on my receiver the "overload comes on ant it cuts off!
You were lucky the overload protection circuit kicked in, congradulation on finding it.
Mar 14, 2012 | Optimus STAV-3770 Receiver
A few seconds after pressing the power/standby button on my SR-96 an acute click can be heard. Currently, from what seems to me to be the same area as the aforementioned click, a similar click can be heard...
The clicking is probably from a relay that is protecting from an overload either misinterpreted or real. Overload circuits can also fail or you have a component that is intermittently shorting causing a momentary overload.
Mar 27, 2011 | Marantz SR-9600 Receiver
My technics receiver stop playing, and display an overload message. what do you believe the is the problem ?
If you are getting an overload problem, it indicates an output load issue. Turn receiver off! remove speaker wires from the back of the unit, this will reset the protection circuit. Now power up and turn your volume right down, If the word overload stays off it means there is a short in the wire or speaker. But! if the word overload comes on "even with the wires and speakers dis-connected" it indicates a short in one or more of the audio output ic's or transistors.
Mar 17, 2011 | Technics Audio Players & Recorders
Display shows overload and receiver shuts down
This means that one (or maybe more) of the amplifiers is shorted. Remove all speakers cables and try again. If you get the same message that means that one (or more) amplifiers is fried. To find which and why you will have to open the unit and test the amplifiers.
Jul 31, 2010 | Pioneer VSX-D412 Receiver
Every 3-4 minutes the a very loud buzzing sound occurs for ~20 seconds. It sounds like it is coming from the compressor area. The fridge and freezer are both working well.
It sounds like the starting components on your compressor are bad. the buzzing is your compressor trying to start and then shutting down on its overload. You will need to replace your starting components on the side of the compressor (start relay and overload) which will usually come in a kit together. Good luck _MJ_
Apr 23, 2010 | Maytag MZD2766GES Side by Side...
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
SA HE200 ~ Overload at power up
First of, be sure volume is turned all the way down before or as you are powering it it.
Second if that does not work disconnect all speaker, and input/outputs.  Power the device on and see if it says overload.
If it does skip the rest of these steps, your capacitors are bad or the power supply is no longer functioning correctly.
If it doesnt, start with testing each speaker at power up.  Match the speaker to the output it goes on, power the device see if it says it.
If it does on any speaker test it is a speaker issue or a terminal issue.  To test for terminal or speaker issue plug a different/ known to work speaker in that same terminal, if it doesnt say overload it is a speaker issue, if it does say overload it is a terminal issue.
Once you have made sure all speakers and terminals work correctly start plugging input and outputs in and test individually.
Jan 09, 2009 | Panasonic SA-HE200 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
It just starts and stops after few seconds ...
It sounds like either the compressor is bad, or the overload and relay assembly mounted to the compressor is bad. The easiest way to determine which is to put an amp meter on the power wire to the compressor assembly. It should only read a few amps while running. If it reads excessive amperage, you have a bad compressor. If you do not have an amp meter, then you could just go get a start relay and overload from a parts store and try changing those parts, as they are much cheaper and eaiser than changing the compressor....just unplug it before messinfg around inside the overload cover on the side of the compressor! Good Luck!
Oct 10, 2006 | Bosch Exxcel KSR34423 Refrigerator
81 people viewed this question
 Grubhead
Grubhead
