Mit dlp showing error code of 44 ( dvi cable disconnected from light engine)
I am a tv tech that is working on a mitsub dlp that is showing an error code of 44, ( dvi cable disconnected from light engine.). the cable pins are checking ok, and the solder connections on both the framer module & interface module in the main cluster to the left of the light engine check fine. am I looking at a bad framer module, or maybe a bad board in the main cluster? I have already changed the 1000ufs@ 16 in the DM, & also the 3300ufs in the power supply that feed 5v over to the ballast for startup, but I have never seen this type of problem before. any help would be appreciated.
thank you,
david klebs
klebsguitars@yahoo.com
  • mkzar Jan 18, 2009
    I had red status light and an error code of 12 - everything ok. Replaced 3300uf's and others on the power board and 1000ufs on the DM board. Now I'm getting error 44 for a DVI cable. I feel like I fixed something! But I think it is either a bad power PCB or optical engine. Not sure I want to waste any more money on this 52525. Anyone have any ideas?
SOURCE: Finding a Ballast for Mitsubishi WD-62327
Try rubbing one out to porn
Posted on Feb 03, 2008
SOURCE: M50WH72S
go to:
http://personafile.com/RCA-50-DLP-High-Definition-Television-Stand-Included-M50WH72S-P034909000018.htm
There you will find the information that came with the TV.
Posted on Nov 23, 2008
Shuttle83
  • 1139 Answers
SOURCE: ws-55511 DM 5volts draged down blinking led
Did you check the caps on the DM board? They usually go bad after a period of time. Remove the DM board and the metallic cover and there should be 4 to 7 capacitors (There are different revisions of the DM board). Check these caps also, replace if needed.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Posted on Apr 14, 2009
  • 668 Answers
SOURCE: want to replace caps which board is the DM board?
Once you take the shield assembly off, you will see a board, I believe it is the DM Board board. There are four Capacitors grouped together probably rated at 35v 1000 mfd, 105 degree. They should be replaced with 35v 680mfd,105 degree Capacitors. Now once that is done, there is another board under that one. This is the Format Board. It also has 4 Capacitors that should also be replaced. They are the same value as the first Board and should be replaced with the same 35v 680mfd, 105 degree Capacitors.
Please note the Flex connectors at the bottom of the DM and Format Boards. They may not be available from Mitsubishi any more so be gentle with them and make sure the are installed properly when reinstalling the Boards back into the chassis. There is one other Board you should look at. The Power Supply Board is the board on the back of the chassis and also has a number of Capacitors that fail. Most all of the Capacitors that fail through out this chassis will have bulging tops. So any you see bulging, you should replace whether they are on the DM, Format , or Power Supply.
I hope this helps,
Skyassoc
Posted on Jan 07, 2010
SD Tech
  • 14553 Answers
SOURCE: I have a Mitsubishi WS-65909 w/a steady blinking
Only one of two reasons for your problem--either the DM is bad OR:
These sets sometimes develop a problem with the front keyboard---micro switches in back of the plastic buttons can fail (reset one is common).
Remove front speaker grill and inspection plate behind it and follow the group of wires coming down from the front keyboard to the right top edge of the opening.
About 8 inches to the right you will find two plugs that are inline--they go to the keyboard--disconnect both and turn set on with REMOTE (remote receiver is behind the screen).
If the set now functions you have a bad micro switch on the keyboard (most likely the reset) and two choices---either leave the keyboard unplugged and just use the remote or remove entire screen and get at the circuit board and locate and replace defective micro switch.
Lots of people miss this as a possible choice--easy to do to either know it is the keyboard or not.
If set does not operate this way DM is bad regardless of how caps look.
Posted on Feb 08, 2010
Testimonial: "Thanks. I had found and tried the front control panel solution prior to your response but to no avail. Thanks for the help. Take care."
How do I fix DVI cable between FMT and Engine disconnected
Are you sure its disconnected? It may have a FMT failure. The cable is inside the back of the TV. you need to remove the rear panel to see it. There should be a white ended cable that plugs in that looks like a monitor wire but short.
Sep 15, 2015 | Mitsubishi Televison & Video
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Tv doesnt show anything
Got (if model listed is correct) any blinking lights?
Set has a self check:
Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
May 29, 2012 | Mitsubishi WD65737 65" DLP TV
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD52725 DLP
Your DVI Cable may be defective as a 44 code is DVI cable
Jun 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62327
The error codes are all different for the various models. But your WD62327 is the VK26 chassis DLP heres the error codes and the meaning for your model. Let me know if you need more help.
12 No Error detected, check Power Supply
32 Lamp Cover is open
33 Air Filter Cover is open
34 Lamp abnormality
36 Light Engine (DMD or LAMP Fan stopped)
37 Exhaust or Lamp Ballast Fan stopped
38 Lamp temperature high
39 DMD temperature high
41 Short is detected
44 DVI cable between FMT & Engine disconnected.
May 23, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Error code 1 2
I found this list of codes
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WSB55
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
33 = Air filter cover is open.
44 = DVI cable between FMT and Engine disconnected
Feb 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Jan 29, 2008 | Mitsubishi WD62628 62" Projection HDTV
Mits WD 52525 format issue.
Jan 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
