Question about HP Photosmart 2610 All-In-One InkJet Printer
The 2610x1 hp photosmart all-in-one - what year is it?
I have 2 Phototsmart all-in-one machines. Which one is older and what is the difference between the two models? PSC 2401x1 and PSC 2610x1
What is the year for each model? I need help.
  • firestarter4 Feb 10, 2008
    Exactly correct. I tried the web site but got no help, so I called Office Max and they found out for me. Best Buy was nohelp. Thanks for confirming what I found out
    Problem Solver:
  • 7 Answers
Think the 2610x1 is the newer, but if you do not have the paperwork, go to the manufacturers web site for more data.
Posted on Feb 09, 2008
6ya staff
SOURCE:
Print cartridge(s) missing or not detected
If you are getting Incompatible ink cartridge error and These cartridges were replaced a year ago, I think its time you call them once again. ( 1-800-474-6836 ) and report the issue. They will ask you for the Cartridge details like part # and expiry date on the cartridge.
Regards,
Sean
Dec 24, 2012 | HP PhotoSmart C4385 All-in-One Printer
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
Hp phototsmart c6100 faxing error 346 when a client is sending me a fax
follow the trouble shooting from the below documents
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&lc=en&dlc=en&product=3645100#Error344
and this is the best resolution that we can give you ........................ thank you
HAMID
Oct 20, 2009 | HP Photosmart C6100 All-In-One Printer
My HP Phototsmart C3180 will not print because it tells me that there is no paper in the feed. There is paper there. It tells me to push the "OK" button once paper is there. I can't locate an "OK" button.
You can see the OK button in the window which says "push the "OK" button once paper is there" , This is not on the printer, its on the Windows dialog box itself..
Rate this solution
RNJ VINOD KUMAR
Sep 15, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Phototsmart C8180 Ink system failure
The printer should have its own ON/OFF switch (or button).
Always use that control to turn-off the printer.
The printer reacts to the 'OFF' signal by properly shutting itself down, and then cutting the power to itself.
Sep 14, 2009 | HP Photosmart C8180 InkJet Printer
I can't scan anything on my HP PHOTOSMART C4345 All-In-One
Try this: Power down the computer and printer, connect the usb to a different usb port. Reboot. The Mac should register the changed location.
The older apples used to be very sensitive to port selection and peripherials serviced. Perhaps they still are.
Regards
apeal
Aug 21, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Paper jam in an HP Photosmart all in one 3210
look at the rear of the machine for an access door.
Feb 03, 2009 | HP Photosmart 3210 All-In-One InkJet...
My 8250 printer s/n my59sh1w293 failed to ID sd card to feed to photosmart software on my computer (even though I have used it for 2 years) I bought another HP printer 7460 to replace it (s/n my855kg0ff)on...
Hi larry,
Did you try a different SD card if yes then you might need to get it serviced ...could be an problem with the card reader.
contact HP:1800-474-6836
Regards,
Debroy
Senior tech HP
Nov 24, 2008 | HP Office Equipment & Supplies
How do i upload videos from my camera a file on my computer?
What uploading application are you using? I'm having the same problem and I have no idea what to do.
Jun 29, 2008 | HP Photosmart M525 Digital Camera
HP Photosmart 2610 All-In-One InkJet Printer Logo
131 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
