ASUS P4P800 SE  Motherboard
Problem for ASUS P4P800 SE (890552603657) Motherboard
Fans runs but no post,no beeps.
By repairguy1 on Jan 27, 2008
When turned on the fan runs, no beeps no post.
Have checked most of the power fets,seem to be O.K.
Tried memory replacement, CPU,video card,bios chip.
Is there any common problems with this boards?
I have another P4P-800SE board that is the same way.
Thanks Steve
Clarification Request
Posted by jsope on Feb 22, 2008
I have the same problem as Steve. How do I check if the POST was completed. When I turn on the PC I the pc fan and Hard drive spinning, however what can I use as an indicator to check the completion of POST. My issue started after blowing off the thermal compound for from the intel chip. Is it possible that a short occurred? I followed the above steps, but no success! Please help, I need a computer.
Hope to hear from you soon. Thanks in advance for your time.
Best Solution
posted on Jan 27, 2008
Helpful)
printerhater
Rank: Wiz
Rating: 83%, 75 votes
The best advice I can give you is to remove the motherboard battery (UNPLUG THE PSU BEFORE YOU WORK ON THE MOTHERBOARD) and let the system sit for about an hour. If the CMOS settings are corrupted, removing the battery will erase the corrupted data in the CMOS, which will automatically reset the CMOS to the default settings... Then, plug the battery back into the motherboard, and try to boot the system...
If that doesn't work, you should disconnect EVERYTHING attached to the PSU, and remove ALL of the add-in cards (modem, NIC, soundcard, TV tuner, whatever you have), and install ONLY the CPU, the heatsink/fan (don't forget to PLUG THE CPU FAN IN), ONE stick of RAM... you get the idea. DISCONNECT the HDD, the FDD, the optical drive, and ANYTHING ELSE from the PSU. When you're ready to test the system, you should have ONLY the CPU, the HSF, and one DIMM plugged into the motherboard. Attach the PSU connectors (both the main ATX connector AND the auxiliary 4-pin 12-volt connector) to the motherboard, and try to boot the system. If it works, SHUT DOWN and UNPLUG THE PSU; then install ONE component (the floppy drive, for example), reattach the PSU, and reboot the system. If the system POSTs, shut down, unplug, and add another device. If the system does NOT complete the POST process, the last piece of hardware you installed is probably the culprit.
Take your time with this; be methodical, and make GOOD notes about the steps you've followed, so we can help you work through this problem...
Best of luck to you; keep us "posted" on your progress...
Comments:
Jan 27, 2008
- Forgot to mention that you need to install the videocard, if the motherboard does not have an onboard videochip... Sorry about that; I was talking on the phone helping my nephew troubleshoot a computer problem while I was typing my original reply to you...
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 07, 2009
Not Rated)
polsar
Rank: Apprentice
Rating: 0%, 0 votes
i had same problem and more too. I tried several ways and i found at last. when i press start button evrey thing is fine but not boot. mobo chip had high temperature and HDD led was on. to boot i reset it. Then reset don!t solve problem. And i opened case and started to applay force on somthing. When i applied force on agp slot, HDD led gone off. I shutdown and restart. My mobo boot normally. Try this. Try this.
Pray for me! Thats all :D
Was this helpful?
Yes
No
Solution #3
Not Rated)
djnick989
Rank: Wiz
Rating: 81%, 958 votes
try cleaer cmos try new power unplug cd roms use 1 ram when u boot up use less power to see
Was this helpful?
Yes
No
Popular Solutions for ASUS P4P800 SE Motherboard
Questions and Unsolved Problems for ASUS P4P800 SE Motherboard
Do you recommend ASUS P4P800 SE (890552603657) Motherboard?
Answer
Answer
gateway laptop powers up but screen doesn't come on
Answer
jumper was blown off during maintence,i put it back to where i thought it was only to discover i... (More)
Answer
how do i activate my built in web cam on my laptop. it is an acus..
Answer
I have two laptops on one laptop when i plug my pinnacle movie maker into the usb the green light on... (More)
Answer
Cuando enciendo la computadora , me sale una pantalla az?l con el c?digo p4p8oos-x . No entiendo... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
