Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Side Buttons - Not Responding (wrong input?)
I have a 19' Gateway FPD1960 Flat panel. It's been working great for over 2 years until last night, in the middle of use, I was checking what inputs it had by slightly tilting the monitor, when I set it back down and powered it up, the light went blue, the No Signal RGB Dialog came up, then the monitor light went orange. This is now happening every time I push the power. It seems to me that I bumped the Input button on the right side of the monitor and it's stuck on the DVI input or something. I can't do anything about this however due to the buttons not doing anything at all (no menu, no response from Input button).
The monitor is still being recognized by my computer, it shows up as a display device, and I can extend my desktop to it (it even knows the model number) when the monitor is On (blue light or orange light).
Please help! I need to get this fixed today! thanks
  • Cawin Jan 28, 2008
    They buttons click and seem physically responsive, just no actual response...
    Any other ideas?
  • Cawin Jan 29, 2008
    Hey, thanks for the help, it's still not working however.
    There is no problem with the lamp or anything of that nature, as I stated earlier, the No Signal R G B comes up.
    After some experimenting, I've found that the DVI port is full functional but the VGA is not. Curious...
  • 1,554 Answers
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Posted on Jan 27, 2008
  • Karl Whisenand
    Karl Whisenand Jan 29, 2008
    no matter what input its in, the diagnostics will show.
    Unplug the video cable and turn on the monitor ,
    If nothing you may have killed or loosend a connection to the lamps.
    if you hold it at a angle under a bright light do you see the desktop.
  • Karl Whisenand
    About the only thing you can do is open it and trace that side cable. they usually push in and can easily be pulled out.
    likley the tack wasn't strong enough.
    Some open from the back but most you remove the bezel first, it should unsnap easilly.
    try not to put any pressure on the lcd as it will leave black marks forever.
    Not many folks work on panels yet except laptop guys.
Is the FPD1960 HDCP compliant
No, it's not HDCP compliant, I can see other owners who've tried to use it with a PS3 (that requires a HDCP compliant screen) and it's not worked.
Mar 09, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
A bright Glare on the right side of the LCD Monitor screen.
thats a dead pixel that cannot be repaired w/out a part or module replacement
Jan 23, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Oct 17, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 monitor power suply
Cleaning won't do it.
It probably needs all new capacitors on the board. are any canister looking components bulged up at the tops ? This is the most common problem on the ones I fix.
Oct 10, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 TFT works with laptop, not desktop
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Mar 18, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
147 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
