Question about Kenmore Brew 'n Wave 63992/63999 Microwave Oven
Water leaks out during making coffee
When I start making coffee it leaks down and out of the microwave. I have put a pan under it so that it stops destroying the counter it is sitting on. How do I stop the leak. I have put vaseline around the rubber gromet where the water holder plugs into the microwave but it hasn't stopped the leak. What do I do now????
  • Karen Finlaw Feb 21, 2008
    I too have the same problem. I also know where its coming from. On the side of the plastic where you put the water in...it has craced on both sides. I see no reason why this would happen when you dont even touch or bother with the sides. Now I cant even find a replacement for it.
  • barbieky Apr 17, 2009
    That is the same problem I am having. Can't figure out what made it crack. I just fill the water half way now but would love to find a replacement.
Sorry for the typo..it should say Cracked..
Posted on Feb 21, 2008
We have water leaking from the back of the frige, coming from under the area where the copper tubing connects from the wall to the actual refrigerator. I can't identify exactly what's leaking. I doesn't...
This can be an auto defrost condition. If your fridge is auto defrost, what happens during the defrost mode, ice build up is heated (in the area immediately near the evaporator coils, not in the main area) . This ice becomes water and drains out via a small tube, typically at the back or bottom of the machine. This water normally goes into a pan under the fridge, and evaporates without the user being aware of it.
If anything causes excessive ice build up (opening the door too much, door seal leak, etc.) then you get too much water and the pan overfills and spills out.
I suggest that you remove the pan from under your fridge, clean it, and put it back, and test to see if yo actually have anything wrong, or not.
This leak would NOT be refrigerant, as you would cease cooling if so. it is all condensation, which is physics and normal...
Mar 20, 2011 | Microwave Ovens
My coffee maker has stopped making full size coffee cups - it spits a bit of water out and then stops
put some vinger and water mixed and see if this cleans out resdue from water out of the lines.
Feb 27, 2011 | Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Water leaks from the bottom the ice maker is not hooked up and the pan under the refrigerator is not full freezer is not sweating neither is refrigerator side
whats this got to do with a micr wave?? But in reply to your question,, if the pan is always full under your Fridge, your evaporator isn't working correctly
Aug 02, 2010 | Microwave Ovens
AMANA UPRIGHT FREEZER LEAKS WATER FROM THE DOOR
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 14, 2010 | KitchenAid Architect II KBHS109SSS...
Ice jam in haier freeze
No you can use a hairdryer to melt it.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Dec 12, 2009 | Microwave Ovens
Always finding water on the floor under the fridge
Nov 06, 2009 | Microwave Ovens
Kenmore Microwave / coffee maker leak
I have a Kenmore Microwave with built int coffee maker (Model 721.63999303). The coffee maker works, but the microwave doe not. Can the microwave be fixed ?
Apr 12, 2008 | Kenmore 63993 Microwave Oven
Kenmore Brew 'n Wave 63992/63999 Microwave Oven Logo
216 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
