Question about Sanyo EM-P672W Microwave Oven
EM-P672W Microwave is not working after some beeps.
    Scholar:
  • 43 Answers
Is anything working? Light when you open door? Is your area prone to have Voltage Surges? Did anything else in your home fail at the same time? These may sound like DUMB questions, but they are necessary.
If the light comes on when door is opened then the FUSE is ok. If the light comes on, but nothing else, you have lose a Control Panel. Perhaps from power surges.
Posted on Jan 28, 2008
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Went to heat something up hit 30 seconds and microwave just went off..no power..won't turn on..
this is the normal way they die,,they some times go with a bang and some times go with a wimper,,this one went with a wimper,
its most likly to be a fuse blown but why did it blow??? they just dont do that unless there is a fult in them
however the fuses are not normal type fuses and trying to get to them your putting yourself in grate danger,, there is a very big capasitor inside the microwave its a real killer too, holding 1000,s of volts,,,,,,,,, tuch it,,,,,,, and your dead!,,,,,, be warned,,,
Mar 14, 2010 | Sanyo EM-P672W Microwave Oven
EM-G5596V Sanyo Microwave - Start button does not work
MY KIDS WERE USING THE SHARP MICROWAVE R-9H94B FOR A TIMER WITH NO FOOD IN IT. IT NOW DOES NOT WORK AT ALL. IS THERE A FUSE OR A QUICK FIX TO THIS?
Jan 01, 2010 | Sanyo Microwave Ovens
I have a sanyo EM-S625S microwave and it won't stop beeping and won't allow me to use any buttons can you please help?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, you likely have a shorted membrane keypad.
You can locate Sanyo manuals, part distributors and authorized servicers
here.
Dec 11, 2009 | Sanyo Microwave Microwave Oven
Replace fuse in sanyo em-z2000s microwave onen
try replacing the fuse.there might just be a voltage fluctuation in your locality
Mar 16, 2009 | Sanyo EM-Z2000S Microwave Oven
Light out
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 02, 2009 | Sanyo EM-P672W Microwave Oven
Sanyo EM S8597V 34 litre, 1000 Watts microwave
I would think you can get warranty service even without the receipt.
Dealers may insist on that, but manufacturers will usually honor their warranty if you give them a valid serial number, and some may require you to sign an affidavit that you bought it at an appropriate date.
I would contact Sanyo support via here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 19, 2008 | Sanyo EM-S9515W Microwave Oven
Numbers and light, but no power
It sounds like you have a bad control unit (the circuit board). We repair controllers nationwide for $39.995 in most cases, but if a part is needed which we cannot get, then it will need a new board. That can be ordered from http://www.vancebaldwin.com If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 06, 2007 | Sanyo EM-P672W Microwave Oven
Sanyo EM-P672W Microwave Oven Logo
166 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
