Question about LG LRSC-26922 Side by Side Refrigerator
Door How do I get inside the door to replace the funnel and its hanger
  • Anonymous Apr 05, 2008
    My ice funnel came off... I ordered a new funnel online, but do I need to order a new funnel bracket as well. The bracket seems to be fine, but the funnel it self has two broken off tabs...
  • 489 Answers
Yes, LG has an updated funnel that requires the bracket to be purchased as well.
To get inside the control panel, look at the bottom edge of the control panel.  You will notice a small hole where you can slip a screwdriver in.  Gently pry open the control panel to gain access to the funnel bracket.
Posted on Apr 27, 2008
My keys are locked inside how should I open
Straighten out the metal coat hanger and bend one end of the hanger into a hook shape. Make the hook about one inch.
Place the end of the metal coat hanger with the hook on it between the window and the frame. Place the hanger 1/2 an inch behind the door handle toward the the edge of the door closest to the rear door.
Push the hanger down about two feet into the door frame. Pull up on the hanger until you feel the hook catch onto the metal arm inside the door frame that controls the lock. You may have to try a few times before the hook catches the metal arm.
Pull up on the hanger once the hook has connected to the metal arm until the door lock unlocks. The lock handle on the inside of the car will move once you have connected the hook to the metal arm that controls the door lock.
Jul 22, 2012 | 1993 Audi 90
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door Problem
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
How do i unlock door with a clothes hanger
Take a wedge (plastic preferably) and wedge a bit between the door and roof enough to get hanger/wire inside to activate the power lock mechanism on the door panel. You risk scratching the paint doing this, but it has worked for me in the past, or you can trip the door lock with the wire.
Oct 03, 2010 | 2005 Chevrolet Cavalier
1998 accord coupe door will not open drivers side from inside or out - power lock works fine
You are in a very unfortunate situation and it may be difficult to fix this without damaging at least one expensive door part. Try this first. Roll the window down. Have a person stand and shake the door back and forth as you attempt to activate the inside handle, then repeat with the outside handle. if the door does not budge you can assume the lock mechanism has become "unhooked" from the lock actuator and the door is locked. Take a metal coat hanger and fashion it into a long wire with a "hook" fashioned in the end of the coat hanger. Try to move the hanger to the area where your door lock attaches to a rod that unlocks the door and try pulling in an "easy motion" on anything you can "hook" in the area of the door lock. Do not pull hard enough to "bend" any metal rods here. They won't work well if you attempt to bend them back later and you migth have to replace any parts you bend. You can also attempt to pry loose the door panel from the inside so you can attempt to see what is broken and take corrective action but you may break the door panel and would have to visit a junk yard to replace the inside door panel. If you can find a good mechanic's manual, you may be able to view an illustration of the lock mechanism for the door and this might make your task easier. Once the door is open you will need to carefully use body tools to pry each "plug" out along the door panel edges, remove any screws in the door panel around the handle or electric switches and remove the panel to fix the broken lock mechanism. It's possilbe that something as simple as a small plastic connector holding parts together has broken off.
Aug 03, 2010 | Honda Accord Cars & Trucks
Inside door handle stopped working
the inside door hanger came off you need to remove inside door panel a couple of screws and need to pop off panel to replace hanger
Mar 14, 2010 | 2006 Ford Fusion
How to open car door when lock out
you can just take a old coat hanger put it on inside of the door if power locks and push down until you can reach locks and push power button real carefully! tak1e coat hanger and un twist and push through the seal on inside of door
Feb 20, 2010 | 2004 Lexus ES 330
Locked keys in car.need picture of inside of the door to see how to open it with a coat hanger
BE EXTREMELY CAREFUL!! pull top of door out with your fingers and wedge something in the gap. doesnt have to be a huge gap just enough to get a hanger or whatever you choose to use. if it has lock button you can directly push with hanger or whatever. if no button you can bend a hook on hanger and snag door lock and pull open. good luck!! BE CAREFUL, DO NOT PULL DOOR TO FAR. JUST ENOUGH AS NEEDED. let me know how it goes!!!
Jan 09, 2010 | 2001 Toyota Echo
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
Position the door with the hinge hanger slots
almost parallel to the front frame.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
LG LRSC-26922 Side by Side Refrigerator Logo
136 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
