Question about GE 21008GE2 Dual-Handset Cordless Telephone
Second phone not working.
Our second phone wont work. It will turn on but will not recieve a dial tone.
From the manual:
VERY IMPORTANT: BOTH HANDSETS MUST BE REGISTERED TO THE
MAIN BASE BEFORE USE. After the 2nd handset has charged for 16
hours, place it on the main base station for 20 seconds, it will then
automatically register and verify its security code.
Posted on Jun 23, 2008
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
MY LEXMARK X125 STOPPED RECIEVING AND SENDING FAXES. IT HAS ITS OWN LINE NOT CONNECTED TO COMPUTER. ALSO MY SPEAKER DIAL TONE IS NOT WORKING. WHEN CHECKING MY DRPD WONT SET UP EITHER. THIS JUST HAPPENED 2...
Hello. If everything else is working, printing and copying, unplug the printer from the power source. Check the telephone line from your phone company by unplugging the fax machine from the wall jack where it is connected to. Plug a telephone device straight to that wall jack and check for a dial tone. If there's no dial tone, contact your phone company. If there is, plug the fax machine back to that wall jack. You can also try replacing the telephone cable with a another known working cable. Plug the printer back to the power source. Check again. Hope this helps.
Mar 23, 2010 | Lexmark X125 All-In-One InkJet Printer
My handy tone-486 box keeps flashing red every 3 seconds and I have no dial tone. My internet works and I have power and a working phone line to the box. Help.
Lifted this straight from the manual:
Button flashes every 4 seconds
(if SIP server is configured)
HT–486 fails to register
So basicly, that means your HandyTone 486 ATA fails to register with the SIP-server. That means you either have not recieved your IP-tele yet, or that your ISP have failed to register you.
Mar 04, 2010 | Grandstream HandyTone 486 ATA (HTATA486)
Home phone
my phone has a dial tone but wont dial out or recieve calls.
Sep 23, 2008 | Motorola Mobility AT&T Prepaid Free2Go...
Problem with fax
I'm no expert but, did you try touching the online or hook button on the fax to hear the dial tone? Or connect a basic home phone into the phone jack at the wall the fax was plugged into. Do you get a dial tone. If no dial tone, call the phone company. If there is a dial tone, its the fax.
Nov 27, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
Lands Phones Logo
171 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
