Question about Zenith B27A11Z 27" TV
Video noise at bottom of screen
This is an older tv by zenith, 1989. It works well and has a nice picture. However, when I play a vhs tape I notice a small amount of video noise across the bottom of the screen. I hooked up the vcr to another tv and I don't see the problem. Also, this only happens when watching a tape, not tv programming. Any ideas? Thank you.
  • marcus58 Jan 28, 2008
    I tried the tracking adjustment. No help. Also, I thried a head cleaning. No help. The VCR is connected through the RCA inputs.
  • 139 Answers
Try adjusting the tracking on your VCR. This symptom would typically be caused by a slight tracking error in your VCR or video heads that need to be cleaned. Your Zenith TV may be a little more sensitive to video synchronization problems than your other TV is.
If VCR tracking adjustments have no effect on the symptom, then the problem could be in the TV, but I'll need more details to assist you with troubleshooting. For example, how do you connect the VCR to the TV?
Posted on Jan 27, 2008
  • networkmagic Jan 29, 2008
    As you originally suspected, this appears to be a problem with the TV....related to the video (RCA) input...probably in the input selection circuitry or first video amplifier stage. You'll need the services of a qualified TV repair technician to isolate the exact cause and replace the defective parts.
My HDD & DVD/video cassette recorder model No RDXV60KB is connected to an analogue TV by scart lead. When I play VHS cassettes I sometimes get sound, sometimes no sound, but always on the screen only...
I dont think you will be able to get the video picture to work, unless you connect a UHF lead from video to TV then tune tv into video. Digital and analogue generally dont talk to each other.
Hope this helps.
Apr 07, 2011 | Toshiba Televison & Video
VCR Sound but no picture
If the picture is only "snow" then the problem is the head(s) on the spinning drum have become clogged with video tape emulsion which greatly affects the spinning video head(s) reducing the video level down to only noise. This usually will happen instantly and is caused by the particular tape you were watching. The head(s) can be cleaned with a lint free cotton cloth and some alcohol by wetting a portion of the cloth with the alcohol (not to much) and with your finger hold the cloth with slight pressure against the horizontal slightly slanted slot which is on the outside surface of the drum about half way down. While applying the slight pressure spin the top of the drum around counter clockwise. do this for about 15 seconds. then when you are sure the alcohol as evaporated from the drum turn it on and try to play a tape (not the one you were watching when the problem occurred) and if the picture is still just snow repeat the procedure but this time use a little more force on the cloth. Or find and use a special VHS head cleaning tape. The cleaning tape will reduce the life of the heads because it is abrasive in nature.
I hope this helps you!
Jan 15, 2010 | Zenith IQC50H95W 50" Rear Projection...
Why won't older Sanyo VCR playback VHS tape on new HD-LCD TV?
The problem is not with your TV. I have had this problem as well and the older the VCR gets the harder it is for it to turn the tape. Does your VCR react the same way with other tapes? Try Fastforwarding the tape about halfway and then test it again.
Jan 06, 2010 | Sanyo Televison & Video
This is a common problem usually seen when playing copy protected tapes. The part of the picture affected is normally off the top of the screen. Sometimes the problem is also due to the VCR itself and differences in tapes. It's also possible for the TV itself to be causing this, although you would probably also notice this flag-waving (that's what it's called) on regular TV viewing if that were true.
Sometimes increasing the height of the picture can push the affected area off the top again. But this can also cause you to lose part of the picture you want. Also, the height adjustment may be difficult to find as it's not something normally used. On some TV's it's a small pot somewhere on the board, but most newer sets have electronic adjustments through a service menu that you need to know how to access.
I'd suggest trying another VCR first and play one of the tapes you know shows the trouble. That might be all it takes. Then consider trying to increase the picture height if it's just a small bit at the top of the screen.
Mar 12, 2009 | Zenith B25A11Z 25" TV
VCR sound works but no picture
It could be that the video heads are just clogged.
Get a known good video tape and put it in the unit and let it just play and play and play. Quality video tapes have head cleaning substances built into the tape. If this does not work, get a Scotch Black Watch tape head cleaner. If that does not work the the heads are bad or some other problem.
Jan 07, 2009 | Zenith ZHX-313 System
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
VCS 442 Zenith
one way is to connect an antenna to INPUT of VHS, place a tape, press play, STOP and switch VCR\TV switch to TV. u should be able to change the channels from the VHS. If that don't work, u may have switch problems.
If this works, tell the
P.S. The 'blue screen' means that you don't have a signal to the antenna inpur\TV protion of VHS.
Mar 27, 2008 | Zenith VCS442 VHS VCR
Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Feb 11, 2008 | Zenith VRB420 VHS VCR
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Zenith B27A11Z 27" TV Logo
145 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
