2003 Ford F250 Super Duty Crew Cab Logo
Posted on Dec 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F250 Diesel engine won't start in cold weather
F250 Turbo Diesel engine won't start in cold weather . Smoke comes out the exhaust until engine warms up. Runs rough & loud until driven at least 5 miles
  • 1 more comment
  • crestline Jan 02, 2010
    I've been having the same problem, does yours improve if you plug in the block heater? If I start it cold (under 40 degrees outside) without plugging it in, it will run very rough until it warms up. If I plug in the block heater, it will start down into the teens and run without issue. I thought it might be some sort of choke problem but have no experience with troubleshooting diesels.
  • Anonymous Mar 29, 2014
    Turbo
  • Hannah Schroeder
    Hannah Schroeder Nov 28, 2017
    It's strange that your engine is rough and loud for 5 minutes after it starts. I have a similar problem with my husband's diesel truck when I try to start it in the winter, except the engine is loud for longer than 5 minutes; sometimes it lasts for half an hour. I don't know what you're going to do, but I think I'm going to take the truck to a diesel repair service. http://www.hesperiaautorepair.com/servic...
anthony ventura
Level 2:
New Friend:
  • Expert 180 Answers
  • Posted on Mar 19, 2010
anthony ventura
Expert
Level 2:
New Friend:
Answers
180
Questions
0
Helped
70860
Points
428
Check your glow plug relay! located on the right side head
  • George Christ Jan 07, 2019
    Bummer deal. Yes check the code for glow plug trouble and fix code problem. More tips here.https://www.auto-tune-up-and-repair-opti...
X-Trail has white smoke blowing out exhaust pipe when I start up
It's normal for cars to do this in cold weather til the engine warms up a bit. If it's not cold you might have a head gasket going bad causing antifreeze to get into the engine.
8helpful
3answers
Ford focus tdci white smoke problems
What happening is you have a bad head gasket or its starting to go bad. As long a little oil is getting in to cylinders causing that smoke once it warms up that gasket is expanding thus the smoke stops. I would keep an eye on oil levels if it gets milky replace gasket asap. Could also be intake gasket but highly doubt it this sounds like a worn head gasket.
My kia sportage diesel is puffing blue smoke.
Nothing to fix friend. See, in diesel, when cold, there is an electric plunger on the throttle that speeds the idle a bit till warm up. Connected to that same wire is the cold start/temperature sensor. When cold/cool this sensor will excite the plunger to speed the idle, and put more fuel into the engine making the smoke you see, until warm up is reached and the sensor shuts down. You really don't have a repair needed friend.
93 ford f250 7.3 ltr diesal hard to start in cool or cold weather often run battery down have to recharge battery to start. new glow plugs installed 3 years ago. once started good for the day. warm weather...
This engine 'loves' glow plugs! One goes and the others try to handle the amps. Change them and you will have no probs! Other than that, I feel this is about the best diesel truck made!
2answers
We think it is the diesel injection pump but not sure
Sounds like not all the glow plugs are working.It should run fairly smooth on a cold start if all of the glow plugs are working..Also you shouldn't drive off on a cold start with a diesel,Its really hard on the motors..At least give them 10 to 15 min on a cold start..The oil in them is a really thick oil and when there drove on a cold start theres no oil lubricating the internal parts and will cause the motor to seize up..You may already no this and dont mean you drive it as soon as you start it i just wanted to let you know..When you get alot of white smoke it could be two things,Theres water in the fuel which will make it not have much power die and smoke..But if it runs fine when its warm theres some bad glow plugs...Hope this helps you and have a great day
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Have Mazda bravo B2600 4WD ,has white smoke & oil from exhaust. Running rough as if on 3 cylinder
You dont say weather its a petrol or diesel engine as there a slight differance in the answer and if a turbo on a diesel thats even more of a differance, but taking it a petrol .
Well to start with the white smoke Isent smoke its water and after going through the engine it turns into Steam and thats what you see..
Running on 3 clyinders is caused through 1 cylinder isent working as a engine should and has a bad valve or a broken piston ring or more and even a cracked head and gasket letting the water through,,,also the broken ring works like a oil pump as if not firing given you power then it works like a oil pump and pumps it into the cylinder that dosent work only pumping oil into the hot exhaust system while running.CAUSING SMOKE
And if a turbo then could be the turbo bearings worn and pushing oil into the engine and still doing the same as before.
Let me know how you get on. RON
6helpful
4answers
Smokes when I start it, smokes ALOT when I start it, it is embarrassing...... after it has sat for aprox 3-4 hours and I go to start it there is so much smoke that I wait for people to clear the area. The...
I have a similar problem - though my timing is right exactly where it should be
I'm wondering if it has something to do with the build up of carbon in the manifold... the smoke has a blue gray hue as well and defiantely smells like diesel
But I'm also zen with the fact that there's always going to be smoke upon a cold start up... it's the price you pay for a diesel... now if I can just get it back up to 50mpg instead of the 44 I've been getting I'll be happier
1992 gmc sierra turbo diesel starts and idles fine until warm up
It's time for a Italian tune up!
The blue smoke can be one of two thing.
oil drop from the valve stem (from engine head to cyclinders)
or
diesel soot collect inside the exhaust system.
I will take a 5-10 minutes high rpm (not redline) ran on the highway.
Pay close attention to the rear view mirror and look for black diesel soot.
=== I will use Diesel Cleen or similar product to condition the fuel. (keep moisture down)
Use the recommended amount of SEAFOAM oil additive to condition the valve stem seal/rubber parts.
I can not rule out excessive blown by.
Can you get a diesel compression tester?
When was the last valve adjustment?
Please post the actual odometer on the engine and I will follow up on it.
1helpful
3answers
Oil coming out of exhaust and whistling turbo
it sounds like your turbo has packed in firstly the oil seal in your turbo has failed thats why ur seeing oil from exhaust & the whistling from turbo is the vanes in turbo breaking up so i would advise not to use car until new turbo is fitted & inter cooler pipes and inter cooler itself are checked & cleaned for swarf from turbo you can check turbo by disconnecting turbo pipe &inspecting turbo vanes (fins) to see if broken up or any damage to chamber.
Engine misses at startup until engine warms
sounds like a bad injector take it to the dealer ship and have it checked out
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
