Question about Bernina Activa 130
Sewng machine motor housing
My machine is actually a Bernina 830 (mechanical 34 years old) I need to know how to get the housing off the motor so my hubby can replace the brushes
  • 1 more comment
  • Anonymous Mar 25, 2014
    I have purchased a Bernina that has a decal showing it has a 110 V motor inside. However, the previous owner claims to have used the machine for a number of years in Australia (where we have 220V). How can I tell if the motor was changed over to 220V?
  • Anonymous Mar 26, 2014
    "PresserFootPosition lost steps" error message keeps occurring necessitating machine restart.
  • Anonymous Mar 31, 2014
    machine seizes once per revolution of the cam gear until manually crank the hand wheel until get through rough patch, then runs then seizes again and so on. How do i replace the gear and where get the part?
DISASSEMBLY TO INSPECT OR CHANGE BERNINA 830 MOTOR BRUSHES:
Remove the big plastic cover piece on the bottom of the machine with the single screw in the center.
Remove the machine's end panel by removing the single silver screw from underneath the bottom middle of the side panel. Pull the bottom of the side panel out and down to remove it. It comes off easily.
Remove the two screws under the motor assembly (silver screws with black washers).
Swivel the motor assembly enough to remove the belt.
There is a another plastic panel on the motor assembly over the motor itself. Remove the two phillips head screws to remove this panel.
At this point you can see the commutator and inspect the "business" ends of the brushes. (In our case, one brush was almost gone and there was nothing left of the second brush except the spring!)
You can then slide the motor out of the housing. I pushed on the motor pulley and pulled on the other end of the motor with pliers. The motor comes out rather easily, but be careful not to disturb the wires any more than necessary.
With the motor exposed, unscrew the caps over the brushes and remove the brushes.
Our motor's commutator looks significantly worn and the motor may need to be replaced. If you find a source for the brushes or a replacment motor, please let me know! Thanks, John john@jldnet.com
Posted on Feb 17, 2008
  • kdg_surf Feb 16, 2014
    unscrew with what? there is no screw slot
  • Neal Iund
    Neal Iund Aug 15, 2014
    Regarding a damaged commutator with reference to John's comments. If the commutator is damaged, the commutator will have to be resurfaced on a lathe to provide a smooth cylinderical and concentric diameter. Motor brushes will also need to be seated to the commutator since the radii on the brushe ends will not fit to the outside diameter of the commutator. After seating the brushes with a brush seating compound stick, I typically use a fine green Craytex stick to finish or polish the commutator. You will also want to lubricate each spherical bearing in the motor with a class 68 machine oil. Failure to resurface the commutator will not only wear the brushes out quickly, but the motor tends to overheat. Brushes and tools can be purchased...see www.sewtechnical.com
I need a motor pulley for my bernina 830
can you help me find one????
tesaeck@netscape.com Thank you!
Posted on Apr 11, 2011
What would cause a Bernina 830 Record to be sluggish and labored at low speed but run beautifully at high speed? Thank you.
Your beloved Bernina 830 Record needs a good cleaning and oiling. The old oil has solidified and is beginning to seize the machine. Continued use may burn out the motor. Also, other parts will begin to falter, ie the stitch selectors, the feed dogs, the needlebar... These old machines are great but they do require TLC to keep them happily purring.
Wheel on right side that controls the needle up and down is very tight...
Sep 07, 2017 | Bernina Sewing Machines
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Feb 11, 2017 | Bernina Sewing Machines
My Bernina 830 sewing machine makes initial starting noises but does not come on, anything I can check? I've already unplugged and plugged it back in.
Assuming it is an 830 Record (old mechanical, not the new computerized model). If it sounds like the motor is straining but the machine's mechanics are not working, then the machine has most likely seized from old, dried up oil.
This is the method I've used on multiple seized machines and works:
This is the oil port diagram for the 830 Record.
Jan 02, 2017 | Sewing Machines
Concerning 1970s 830 Bernina. There is no motor sound..nothing. Are the carbon brushes in the pedal?
The 830 models varied so I'm not sure. My machine looks like this:
Bernina 830 sewing machine feet pedal accessory box table instruction...
If you scroll over to the photo of the motor, there is a white plug which pulls out. Underneath, there is a screw. The carbon brush may be there. However, some 830s had the speed switch on the machine (right above the knee control) and others have it in the foot pedal.
I found the following information in my computer files that may be helpful: Bernina 830 Motor Brush Replacement
Re: sewng machine motor housing
FWIW, if your machine hasn't been oiled for a long time, you should probably take time to do that. When the old oil solidifies, it sticks the moving parts together. Forcing the motor to try to run the machine can damage the machine. Use fresh good quality sewing machine oil or (I use) liquid Tri-Flow Synthetic Lube and apply a couple drops every place metal rubs on metal. (Wiggle the handwheel and watch where things move.) Do NOT oil belts, synthetic gears, cams.
Oct 22, 2016 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
What is the difference between a bernina record 930 and just a bernina 930
At the present time, Bernina 930 Record and Bernina 930 are the same machine. Although, technically the name is Bernina 930 Record, referring to the mostly mechanical sewing machine produced in the 1980's. They are very coveted machines and one of the more popular models.
However, Bernina has, in the past few years, begun producing computerized machines and labeling them with the same numbers of older mechanical machines (makes things very confusing), ie Bernina 830 Record vs Bernina 830 computerized model. At this point in time, Bernina has not yet produced a computerized 930.
Jul 08, 2013 | Bernina Sewing Machines
Is it possible for me to get a free download of the Bernina 830 instruction manual?
Are you talking about the 'new' 830 embroidery machine or the 'old' 830 Record mechanical machine ?
Nov 04, 2011 | Bernina Artista 180
Sewing Machines Logo
1,524 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
