Question about RCA RT2620 System
I cant hear my speakers
I connected my dvd player to the RCA RT2620 System And i can see the picture and i can hear it also from the tv but i connot hear it from my surround sound speakers...can any one help me?
I have harmon kardon speakers that came with my hp a815n, i recently had to reinstall my operating system, and i can't hear anything from my speakers. i've tried installing drivers and "searching for new hardware" and i can't seem to get it.........please help
Posted on Feb 27, 2008
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
I have a 32 "
Check how you have the satellite cabled. I suspect that you have the video from the satellite to the TV but the audio cable going directly to the stereo. You probably have the DVD audio and video going directly to the TV. (I'm assuming you have the 32LA30rq and not the 32LA30rqd which has a built-in DVD and thus has the audio connection inside the TV.)
Since you don't mention which connection you are using for the DVD player and for the satellite, I will just mention the basics. If your DVD player is connected to one of the HDMI ports, that cable carries audio and video between the TV and the DVD player.
Devices that use component video cables use two separate cables. One cable with two sets of three RCA plugs carry the video; a second cable carries audio with 2 RCA plugs on each end. When you connect these, you do not have to connect the audio to the TV. (Similarly, a composite video connection can be modified for one line with the video signal going to the TV and the audio cable going to a speaker system.)
If my solution is correct, you may want to rearrange things. You can connect the satellite audio out to the TV audio in at the same location as you have the satellite video in. Then connect the TV's audio out (to the right of the component 2 in and above the coax audio out) to the stereo. Then switch the TV speakers off to use the stereo - Menu > Sound > Other Settings > Speaker On/Off. Then both devices will play either at the TV speakers or the stereo depending on the state of the TV speaker setting.
The manual is available here: .
I hope this helps.
Jan 20, 2011 | RCA Televison & Video
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
No audio or sound
I'll assume you mean you want audio from the TV to enter the unnamed 'rca dvd and souround system ' as that is where audio should all converge.
For this purpose you should have an RCA audio cable pair running from the FIXED AUDIO L and R outputs to any available input on the unnamed audio electronics. If you use(d) the VARIABLE AUDIO outputs the TV's volume control would affect the sound at the electronics end.
Apr 05, 2010 | RCA RT2620 System
Can get tuner sound, but not DVD
make sure you are in analog not digital
May 06, 2009 | RCA RT2620 System
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
TV Audio won't come through the Home Theatre Speakers
why it doesn't come. just connect the RCA cable to the output pins of TV and connect them to the input female jacks of home theatre receiver. or if the TV has optical out and the home theatre reciever had optical in. thats the best option. just connect one optical cable to enjoy the 5.1 sound. tell me clear problem if u r nt solved.
Jan 26, 2009 | RCA RT2620 Home Theatre System System
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Jul 08, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
No sound from rt2620 dvd
Hey, you will need to reset your coaxial, optical,analog setting back to the analog. Mine did the same thing.
Nov 09, 2007 | RCA RT2620 System
RCA RT2620 System Logo
164 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
