Question about RCA Universal Remote Control
Rca 3 in `1 universal remote
Tying to set remote to a quasar tv/vcr. need to get to the menu on tv.
  • Anonymous Mar 29, 2014
    need to program my jvc/dvd player to my quasar remote control for my tv.
I am not having any luck setting up my new rca 3 in remote ,, cannot get codes right and just had basic cable in stalled what do i do>??
Posted on Jan 17, 2009
Press tv button and hold it down, While holding down tv button put in code (for Quasar tv: 1054), light will go off then back on when code is entered, release tv button and now remote should be programed
Posted on Jan 28, 2008
I HAVE A QUASAR VV2008 TV/VCR COMBO AND I DONT HAVE REMOTE AND CANT GET TO NO CHANNELS EXCEPT 60 AND LINE
The remote model number for the Quasar VV2008 is VSQS1570 and can be ordered from Panasonic at 1-800-221-7262 or Go to a Family Dollar store and purchase the grey RCA universal remote for $6.00 about 6 inches in length. When you are ready to program it for the Quasar VV2008 push the code search button then the VCR button and enter 0162 then push enter. The red light should go off and the remote should turn the TV/VCR off and on. It worked for me 4/19/2013
Apr 12, 2011 | Quasar VV-2002 20 in. TV/VCR Combo
I have a Quasar tv/vcr combo, model VV2007, I have no remote and bought a RCA universal remote and none of the 3 codes work, the most I can get out of it is channel and volume, I need to add channels but...
Sometimes the universal remotes do not compromise fully with certain models especially with combo models.
So you might a different type of universal type to connect with the Quasar codes, but it is ideal if there is the model mentioned in the manual of the remote.
Volume and channel working is what is most important and should be considered good enough.
Sep 14, 2010 | Quasar VV2007 20 in. Combo
Lost the manual for my rca universal remote
Try these codes for Quasar TVs:
1003, 1054, 1055, 1070, 1109, 1170
Codes can be found here.
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Basically, try holding the TV button, the on/off button should light up. Then press the digits for the code one at a time. If the code is accepted, the on/off button should go off. Finally let go of the TV button. Now try operating your TV.
Apr 06, 2009 | RCA RCR311S Remote Control
Set up for cable
You might be able to restore the factory settings by pressing "play" and "FF" simultaneously and hoding them down until the set shuts off (about 5 seconds). Then when you turn it back on it will lead you through the setup routine, which includes auto channel select.
Plan B would be to buy a universal remote.
Jun 26, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
Older Quasar Video TV combo Model UU1220AW, SN VSOS1226
can you please send me the tv vcr combo code for my philips remote, to the old quasar tv. thank you Genef9@yahoo.com
Apr 20, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Remote
Her is the RCA Universal Remote Codes website:
Hope this helps!
Mar 26, 2008 | RCA RCR450 Remote Control
Quasar 13" TV/VCR lost remote cannot find menu
You must buy a universal remote and be sure and get one that has a menu button on it.
Dec 31, 2007 | Quasar VV-1302 13 in. TV/VCR Combo
How to enter code to control TV
i cant find my quazar set up code 4 head vhq40hm?to put in to my one for all universal remote
Nov 18, 2007 | Quasar VHQ840 VHS VCR
Televison & Video Logo
831 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
