I bought an acer 1916wab 19" widescreen, not sure this question belongs here, but all I get after windows starts is a message saying 'input not supported'. I also noticed a sticker on the base of the monitor saying 'for Windows vista'. I am running Windows XP professional version 2002. Will this monitor work with my system (446MHz, 320 ram)? How do I get it to work? I also have an Acer AL1916WAB and have a "floation" error message that says "Input not supported". The problem is that I cannot view anything on the screen to be able to get into the control panel. The screen just remains black.
I think you have problem with video card or cable, not with two almost similar moitros.
You should check:
Another monitor connected to your pc (test videocard)
the VGA cable's pins
more than that info required
Yes it will but u need to adjust it to 1024x 768 60 hertz in settings menu ok
setting from old scren are wrong so boot in to safe mode hold f8 at start up u see bios startup dont u or no hit f8 then select enable vga mode ok this will reset video adpoters to defult 800x600 16 bit 60 hertz ok
al;so the native reslotion on a 19 in is 1440x900 your video card cant handle this out put resltuoin ok dl allleatest driver for video card but u need hi end model video card to suport better screen like this least fx 5500 pci ok to go in so for now use what i said ok 1024x768 at 60 hertz in advaced screen prpoteries ok
mark me as fix ya ok
