Question about Canon CanoScan 4400f MultiFunction Color Printer
CanoScan 4400f I recently bought and installed my CanoScan 4400f. Under the flip-top, when you first set it up, there is a white, heavy-paper protective sheet that covers 'negative holder' and instructions for loading negatives. One is advised to remove this sheet, which I did. But, now the negative-holder and instructions are there and exposed to the scanning surface when you close the lid. I scanned my first 1-2 pictures and it included a picture of this 'negative holder' and instruction. Do I remove ANOTHER thing from the inside of the flip-top (i.e. this negative holder and instruction sheet)? Thanks, Seth
It's probably long since solved for this person, but you need to use the bundled software and scan AS a negative; what he was apparently doing was scanning as a flatbed image, so it was picking up everything across the entire glass, including the negative holder and it's strip.
Posted on Mar 26, 2009
Keep the protective cover on except when scanning slides or film.
Posted on Feb 05, 2008
Can I connect canoscan 4400f using ethernet cable
i believe is not possible to connect to a router. printers ar designed to be connected to computers via ethernet cables and bluetooth when both devices are bluetooth enabled.(must have a wifi bluetooth ethernet card installed or usb bluetooth installed via usb). is you want to have the printer to be used bye more than one computer at home or office. you must set up each computer to the printer as well.. in control panel look for printers.then set up the conections.if computer 1 is printing a document. computer 2 will have to wait. when done. then will print work for computer 2.
Dec 18, 2012 | Canon CanoScan 4400f MultiFunction Color...
Will not scan slides anymore
Try to install this link --http://canoscan-4400f.software.informer.com/
and then restart the scanner also check the settings in you computer as well. i dont dont have information about your os. so i can help you so much but yeah let me know if you have any further questions or concerns.
Thanks.
Apr 29, 2010 | Canon CanoScan 4400F Flatbed Scanner
Why is my canoscan 44oof scanning in negative mode i.e white paper with black print is scanning black with white print
I solved this problem by the following:
Don't scan from the Canoscan toolbar. Use an imaging program (I used Picasa), import from the Canoscan, and Scangear opens up. In the settings for Scangear, you can choose positive or negative film (use positive for slides). You can keep using Scangear, or after using it once, you'll see it has corrected the problem with the toolbar
Oct 07, 2009 | Canon CanoScan 4400f MultiFunction Color...
Downloaded all the drives and still can use it as the message:"execute appliation" keeps poping up
You need a scanner application such as Adobe Photoshop or other program.
Cannon has one for your scanner at this link.
http://software.canon-europe.com/products/0010399.asp
May 24, 2009 | Canon CanoScan 4400F Flatbed Scanner
Help installing CanoScan 4400F
Here's the link for the drivers, just select your Operating System and language and you should be good to go. It also includes the software that you need.
Canon CanoScan 4400F Software Driver
Sep 18, 2008 | Canon CanoScan 4400F Flatbed Scanner
Color
You may need to calibrate the scanner. This should be able to be done in the Advanced Mode of ScanGear. ScanGear is the scanner driver. Once in Advanced Mode, locate the option to Calibrate under the Image Settings section.
Jul 02, 2008 | Canon CanoScan 4400f MultiFunction Color...
Reinstallation
Always get the original manufacturer's drivers directly from their website. Be sure to select the correct Operating System (like XP or Vista or Mac OS).
Canon CanoScan 4400F Drivers
Thanks for rating this Solution!
Jun 09, 2008 | Canon CanoScan 4400F Flatbed Scanner
CanoScan 4400 won't scan
Try disconnecting other USB devices to determine if it is being caused by some other device.
Mar 21, 2008 | Canon CanoScan 4400f MultiFunction Color...
Canon 440f won't scan
I had exactly as described on my new 4400f scanner. Have resolved by uninstalling the toolbox software (it was at 5.0.1.2), downloading toolbox s/w from canon site, file name is S6A04mux.exe - toolbox 5.0.1.1 Installed this and all works from the scanner front panel
Jan 06, 2008 | Canon CanoScan 4400f MultiFunction Color...
CanoScan 4400f
uninstall all drivers and software that cam with the scanner, and then try installing the software again before connection the scanner... this is a problem when there are two different twain drivers, look for C:\Windows\twain_32\CNQ4803(2) see if there is a driver in there.
Dec 22, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon CanoScan 4400f MultiFunction Color Printer Logo
332 people viewed this question
old marine
old marine
