Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Just bought 42" Aquos but has bad picture quality in Analog & Digital cable
Had a Proscan LCD and looked great! but kept shutting down so I traded for Aquos that was twice as expensive.  The Aquos looks terrible, even with Blu Ray movie.  Don't know how to adjust the picture or what??!!
Please help!!
  • 208 Answers
There is no secret to adjusting the picture settings on this unit. My unit is perfect with Hi Def signal and better with Blu Ray. I assume you are using HDMI cables and have tried a new HDMI cable to eliminate the possibility of a bad cable. If you have done this then the unit has a problem and I would take it back or contact Sharp to get an auth. service center involved.
Posted on Feb 03, 2008
No screen proscan 42la30h
Lcd/Backlight! Main Problem On the led,lcd is the Bad lcd ribbon or Bord, Try turning off all the lights and Turning it on, then kneel down to the ground and see if u can see Channels changing when u click up/dwn or volume or even the Fuzzy look when theres no cable going to it. if u can see then its probably a bad board or chip.
Hope This Helps :)
Mar 08, 2012 | Proscan 42LA30H 42 in. LCD Television
My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Feb 17, 2011 | Proscan 42LA45H 42 in. LCD TV
Sharp 40e67un issues with digital picture quality.
try contacting your cable company and see if they have some sort of signal booster available
Mar 18, 2010 | Televison & Video
Picture not clear
Get a HDMI lead it makes HD tv look how it is suppose to look HIGH DEFINITION. You'd think it naturally is suppose to look great but these people are rip offs you need that additional peice which should make it spot on for you. Try stores such as maplin & currys. Get the gold plated HDMI lead better quality
Good luck
Apr 27, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vizio 42" fhdtv - need help for better picture quality settings
Since you're using "analog cable", I would adjust the television such that the picture is not streched. This means there will be black bars to the left/right of the 4:3 picture, but you should experience some improvement in picture quality because the TV is not trying to interpolate what to do with an already crappy analog cable signal.
You may also want to add a signal booster where the cable first enters your residence... often, folks split that analog signal up so much it is weak... and looks much like you describe.
Mar 09, 2009 | Vizio VW42LF 42 in. LCD HDTV
I have a sharp aquos 52" with a thin vertical red line in center
If you have a thin line running down the screen, you may be looking at a service issue right off of the bat. Here is a few things I want you to try before calling sharp, 1. Reset the unit from the setup menu
2. Unplug the unit for 2 minutes then plug back in. If that does not work. Take digital pictures of the line and call sharp immediately. Make sure you tell the rep you want to sign up for the aquos advantage program that they have(extends your warranty 3 months free of charge!) because that will get you priority service on with your issue. If they cant resolve that line ,9 times out of 10 they will replace the unit. hope this helps you
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound quality poor
Try moving the audio and video cables to a different input.
Or the cables maybe bad. That's what happen to me.
Feb 11, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
May 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
215 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
