Question about RCA 100-Watt Stereo System With 5-CD Changer & Cassette Player RS2653 Shelf System
Cd player on RCA R52653
The unit works fine except...when we insert disc, it automatically turns off after 43 seconds any ideas ? thanks , Carole
  • 7 more comments
  • gagetize Jan 27, 2008
    Only when we try to play CD
    Yes, both your ideas are logical, we know it doesn't overheat because the cd has only been in there 43 seconds before it turns off.. and we have done the lens cleaner. any other ideas ? like
    It ONLY happens when we play a C.D. , the C.D> quits playing after 45 seconds.
    it doesn't freeze up, it just stops playing.
    It sounds more like a timer problem to me ????
    If it was a power cable the radio wouldn't work would it ?
    I have a RCA 5 disc CD/radio player ( Rs2653 )
    The radio plays fine, the C.D. player works
    BUT.........the C.D. stops playing after 45 seconds , it just stops.
    WE have taken the top cover off the set and can now see it. The disc does keep spinning , NOW ......after playing for 45 seconds it stops and starts playing from the beginning again.
    The radio plays fine, it is only the C>D> player that isn't working properly.
    The disc will play for 45 seconds, keeps on spinning and then starts playing over again...
  • fixrthrowit Apr 26, 2008
    I bought this new and have never been able to enjoy the cd player. It will begin to play a cd and stop then change to another cd an do the same thing, or start playing on the 10th song and quit! What a waste of money, and K-mart doesn't take them back nor have I found out how to get RCA to stand behind their product. If I do, I'll post it for others. Tried cleaning it, that didn't work, took the top off to see if any foriegn object was in the lens path. Nothing. RCA needs to fix them at no cost or return consumers money!
    President:
  • 1,944 Answers
Does it turn off only when you try to play a CD or does this happen for other functions as well?
Posted on Jan 27, 2008
  • Damen Wong
    Damen Wong Jan 28, 2008
    It plays only for 45 seconds....hmmm...is there some preview function that was accidently activated? Say, after putting the disc in can you choose any track to play?
    Genius:
  • 1,067 Answers
Overheating or lens dirty in unit buy lens cleaner cd to clean it
  • 2 more comments
  • nick helpap
    nick helpap Jan 27, 2008
    get in it blwo dust out get lens cleaner kit
  • nick helpap
    chokes up freezes
  • nick helpap
    what about bad power cable
  • nick helpap
    shorting out what i ment after so long doe sit do it on all cds or buned ones only can uu open unit up cheak its connection to the cd rom drive
    Sergeant:
  • 226 Answers
So, does the disk kept on spinning while the music stops?
if yes you need to replace the belt of the motor for the lens it maybe lose. this can be performed by certified repair man.
XDVD710 Whenever I try playing DVDs the screen says bad disc the CD and tuner works fine but with the disc inserted I hear thedisc sspinning with occasional beeps then get the bad disc message and the disc...
The laser unit is most likely faulty and requires replacement. There are usually separate laser diodes for the CD & DVD reading, so the CD might work perfectly while the DVD won't.
Jan 18, 2014 | Televison & Video
FUNAI B2735 DVD/VCR COMBO
Have you tried a blank DVD with lower speed say 4X? Or for that matter, some other brand of blank DVDs?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Funai PY90VG DVD Player/VCR
How to turn on rca cd player
Hello
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
Jul 29, 2011 | RCA RS2635 CD Shelf System
Hi. My Philips CD Recorder CDR 785 stops and turn off when i try to recorder from spotify.
The Unit turns itself off automatically after a few (variable) time when simply reading a CD and also when burning, then after 1 or 2 seconds it turns on and goes automatically in stand by mode. Any solution? Thanks.
Mar 08, 2011 | Philips CDR785 3-Disc CD Recorder
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
CD player not turning
the tray should have a micro switch to touch when its closed. maybe it needs some fine adjustment. if it doesnt say closed then the laser drive wont start. or maybe the magnetic clamp hasnt come down onto the disc properly
Nov 09, 2017 | Audio Players & Recorders
RCA DVD player model DRC105N that won't read discs anymore
If the DVD is not reading any CD, then it is often a lens problem.
If th lens cleaner does not work the unit must be taken apart, to clean the lens pickup with isopropyl alcohol and soft cotton tips.
In some case is necessary to replace the lens pickup, as this is defective.
Nov 26, 2008 | RCA DRC105N DVD Player
The laser is damaged/worn out. It would be cheaper to purchase a whole new unit, instead of repairing that one.
Sep 20, 2007 | Audio Players & Recorders
Brand New Unit Will Not Accept ANY Type of CD
I am having the same problem but only with a KDC-MP335 unit. I installed it in a 1995 Jeep Grand Cherokee to the stock system, pretty easy install just matching colors for wires and everything works (Radio). but not one CD plays. it says reading and it acts as if it is playing the tracks but no sound... what is going on? did I mess up wiring it or something?
Oct 03, 2006 | Kenwood KDC-X890 CD Player
RCA 100-Watt Stereo System With 5-CD Changer & Cassette Player RS2653 Shelf System Logo
253 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
