Question about Denon AVR-3300 Receiver
Buzz or hum
Recently the AVR-3300 starting outputting a 60 cycle buzz to all surround sound speakers. You can hear normal audio but there is a constant annoying buzz in the background. Buzz is present right at start-up of AVR and stays constant; never goes away, until AVR is turned OFF.
Buzz is present in all modes; DVD player, Tivo, and radio.
AVR has been disconnected. TV sound system is being used.
Does this sound like a power supply capacitor problem? I can replace capacitor(s) or other componets. I just need to know which ones.
Any assistance would be appreciated.
Thank you.
papaten@comcast.net
  • 64 Answers
Here's a simple fix to this very common problem. The problem is most often caused by a groung loop between audio components. Try this, Get a piece of wire long enough to go from your receiver to the rest of the components. Strip the ends of the wire bare and touch the back or a bare metal (unpainted) spot on the receiver. While keeping the wire attached to the receiver, touch a bare spot on the other components. 9 out of ten times the hum will disappear. If / when it disappears, wrap the wire around a screw on the component and tighten it as well as on the offending component to make it a more permanent fix. Or,, get fancy and crimp proper lugs on the wire and make the connection that way. Looks better and will be more reliable. Just make sure both ends of the wire are touching clean unpainted metal on all offending components.
Posted on Jul 27, 2012
Mine did the same.
The cause was the system that controls the fan. I had to bypass it and run the fan always. Probably finding what between the components that control the fan was better, but not for this old amp (at least for me). The fan that cool finals works with signal output and temperature, if temp is high but signal is low, fan stop, maybe something on this system was broken and the fan never started, making some caps too hot (we changed) and probably final stages too hot and buzzing.
Hope it helps (sorry for my bad english)
temp934-siemens@yahoo.com
Posted on Feb 14, 2008
    Scholar:
  • 67 Answers
My guess would be +and -12v supply to preamp opamps has ripple. (drycaps or bad solder). I may be able to get you a pdf service manual if needed. kstahl65@att.net
Posted on Jan 31, 2008
Hum created by Denon AVR-3300
Look for bad electrolytic capacitors. Swollen up on top or leaking, puffed out on bottom. If they look alright, you will need a capacitor tester to see if any have dried up. That's the first thing I check for hum.
Jan 09, 2014 | Denon Audio Players & Recorders
Surround sound doesnt work. When i switch the surround on there is a buzzing/ hum from the speakers. The sub has a hum in analog mode. I try to switch to theater, club, church etc. And still a hum was...
Back up, open the manual and set it up with test tones to verify the hardware before trying anything else. Then onboard FM. Then external sources (according to their manuals).
Hum/buzz solutions are common on the internet. Do some web searching for "audio system hum" to find somethign that matches your symptom.
Sep 01, 2011 | RCA RT2500 System
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
I have a buzz / static that appears for the first 15 minutes.
Hi...
I just opened up an AVR3300..It's trouble is that it goes into stndby
at once.
The BIG power supply caps are VERY swelled at the top.
That would be my informed view on why it's bad.
I suggest you look at that being your possible trouble too.
Scott in Vermont
Jun 22, 2009 | Denon AVR-3300 Receiver
Denon AVR-3300 has a buzz from all 5 speakers during warm up.
Depending on the location you're living, try to connect a good ground to your system might solve the problem
Jun 20, 2009 | Denon AVR-3300 Receiver
AVR-4800 - After 30 min audio goes out all channels just hum/buzz
if it is under warrantee then fix it.
sounds like a component is over heating, probably cost couple hundred (or more) to fix it, balance that with what you paid.
Apr 28, 2009 | Denon AVR-4802 Receiver
Humming sound (speakers)when HK AVR is powered up.
In my case the buzz was only on front speakers. There are 3 capasitors (100uF/25V) very close to the cooling ribs of 3 regulators in the power supply. In my case the C922 was bad.
Apr 02, 2009 | Harman Kardon AVR 500 Receiver
One speaker buzz when cold
It works fine for a couple of minutes the starts to hum. If you turn up the volume it masks the noise but is till audible, also the video switching cuts out. after examining the components I have seen some heat discoloration in the power suply area and believe it to be power for the video board. disconecting the ribbon cable form the video board the hum goes away, and so does any video wich does'nt matter for me because my monitor1.gif does all the HD video1.gif switching. hope this may help with some noise problems.
Jan 23, 2008 | Harman Kardon AVR 225 Receiver
Rear Speaker problems
The delay is normal as it's designed to create a spacious large room sound. The buzz however, is not. It sounds like the power supply is bleeding into the amp and should be serviced.
Jun 01, 2007 | Aiwa NSX-DS55 CD Shelf System
Denon AVR-3300 Receiver Logo
457 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
