Question about Brookstone Micro CD Shelf System with MP3 Shelf System
Brookstone micro shelf 450577
Should sound come out of the big square box that plugs into the wall? and what kind of battery does the remote take?
tonymemphis
SOURCE: Brookstone Remote Codes fore Universal Remote
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/brookstone/supersized-manual.zip&area=other
for brookstone jumbo remote.
Posted on Jan 10, 2009
  • 403 Answers
SOURCE: brookstone big remote 538755
Here you go. This will work with most all universal remote controls. If you don't have the code do the following: This is mainly for the Brookstone.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Posted on Oct 24, 2009
Testimonial: "These are indeed the instructions from the Brookstone manual (which I found after I finished unpacking)."
  • 65 Answers
SOURCE: Have Big Brookstone remote, now have a Vizio tv,
hold down code search till the light stays red then hit tv then press power repeatedly till it turns the tv on or off imediatley press enter once it does.
Posted on Sep 24, 2010
jyackle5
  • 8197 Answers
SOURCE: need remote codes for the
click the link http://mscustomercare.com scroll to the middle of the page and download instructions for jumbo remote.
Posted on Jan 03, 2011
westytech
  • 120 Answers
SOURCE: Need code Westinghouse TV I have brookstone big
Hello zmprice, I need a bit more information so I can better assist you, what is the model # and serial # of the TV? Depending on the model # if it is an older model # they normally use Sony codes, whereas if it is a newer Westinghouse TV it probably uses Samsung codes.
Posted on Feb 15, 2011
Missing a cable from main unit to sub woofer. where can i buy one
Bought the wafr stereo system, came without the 9 pin male to 9 pin male subwoofer cable. Called the Brookstone outlet I bought it at and they are mailing me one. Cable is actually power and audio combined, specialty cable, you probably can't find one in any standard outlet
Mar 05, 2011 | Brookstone Micro CD System with MP3 Shelf...
Need code Westinghouse TV I have brookstone big digit remote
Feb 15, 2011 | Brookstone Big Digit Remote Control Remote...
Need remote codes for the brookstone big remote. RCA is the tv
Jan 03, 2011 | Brookstone 538744 Remote Control
I bought a cloud force RC helicopter and its battery runs out in 5 minutes, after a full charge. The batteries are brand new. Do you think theres something wrong with it?
The batteries have degraded. Even if you bought the helo brand new, it might have been sitting on the shelf for quite some time since it was manufacturers and Ni-Cad and Li-Po batteries have limited shelf life.
You can always replace the batteries. The stock batteries in the Brookstone Cloud Force uControl RC heli are 3.7V 150mAh, but I I suggest you seach for and buy Syma S107 / S107G Upgrade 3.7V Lithium Polymer 240mAh batteries. I picked one up for my Cloud Force and because it's slightly bigger than stock, you'll need to tape it under the body between the skids, but some people have also managed fit it between the frame where the stock battery rests. Some generic replacement instructions: http://www.micro-helicopters.net/syma-s107-battery-replacement. The 240mAh battery works perfectly and runs the chopper longer than the stock one did brand new. Aside from a year's heavy use reducing this thing's usable run-time to 30 seconds or so, this has been a great micro-heli.
Nov 21, 2010 | Brookstone Toys
Mar 24, 2008 | Brookstone Micro CD System CD Player
Model #704104 brookstone acousticlear
I think you should try to buy a used remote or get a replacement. I just found my manual. It says the "Sleep" button is used to program the clock when the power is OFF. Sorry I couldn't help you. I think my issue is either a burned out backlight or my "backlight" button isn't working on my remote.
Jan 30, 2008 | Brookstone AcoustiClear Shelf System
Radio reception
the wire you use for the antenna is damage replace it or change the set to a other location.
Feb 19, 2007 | Brookstone Micro CD System with MP3 Shelf...
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
