Go to Walmart and get a CD Optics Cleaner Disc. Little brushes clean the tracking and read optics. The error is normally because the tracking optic can't read a disc, so it says there isn't one!
Staples CD drive cleaner contains disk that gently brushes dust, dirt, lint and other contaminants from the disc drive lens. Cleaner is not suitable for use with play ...
Rating: 3.4 · 5 reviews · $14.97 · Out of stock
Product Description Lens cleaner is a compact disc designed to clean DVD players, CD players and game stations. From the Manufacturer Restore your CDs ...
About This Item · Top quality manufactured by Maxell · Automatic cleaning system has instructions on disc · Compatible with CD players and CD-ROM drives · Also ...
Rating: 4.3 · 133 reviews · US$9.09 · In stock
When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
If you are prompted with a Microsoft Windows boot screen, press the Enter key.
After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
Restart the computer.
When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
Press the CD-ROM drive eject button and insert the disc labeled System CD.
Close the CD-ROM tray.
Refer to on screen instructions to select either CDROM or USB CDROM.
The computer will boot from the Recovery Media
When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
Hi, To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer. As the computer is starting make sure to press a key to boot from the CD. In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console. If prompted enter the number of Windows installation you're repairing. At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file. Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps.
Let me know if you need more information
Thanks
You will need another computer that can burn CD's, and obviously a blank disk
Follow THIS LINK and read the article/reviews on the top Windows password recovery applications. Once you choose the one that's best for you, download and install it on Comp #2, follow the instructions and burn the .iso file to a disc.
Access the BIOS on Comp#1 (the one you can't login to) and set the boot order so that the CD/DVD-RW drive is first. Insert the CD you made, and reboot Comp#1. The CD will automatically do it's thing.
hey rose, I'm afraid a normal user won't be able to hook up those old drives to eee. However, you do not need a cd-rom to install the printer drivers. Just download them from lexmark.com homepage and install them from your hard disk! =) Here's a direct link to the vista driver for your version: http://www.downloaddelivery.com/downloads/cpd/cjr2400EN.exe
well, you will need a windows XP cd and a valid product code. you will also need either a USB cd rom, or one of those ide to usb kits sold on ebay (make sure it comes with the molex power adapter), and a standard IDE cdrom drive. connect the usb drive to the eee pc and insert the xp disc, restart and boot to the xp disc and install xp that way.
I have the linux version, not sure if you have the windows version or if it really matters. If you are looking to "reformat", you can go with the other suggestions with the USB stick. However, if you are reformatting to get back to the default settings, power on the computer and immediately hold F9. This will bring you to a screen that gives you the option to "restore factory defaults". You will lose all your previous settings, but if you were reformatting anyway, that's probably not a big concern.
