Router intermittently drops connection to printer and or internet (wired)
  • 145 Answers
Mhat type of router is this? I have had a very similar sounding problem with a few linksys routers. Or it could be somebody trying to crack your WEP key, there are programs that will push you off of your wireless connection to force you to sign back on in attempts to record your transmissions and then decipher such said recorded data to obtain your WEP/WAP pass key.
Posted on Jan 27, 2008
My router drops internet connection every so often. Powercycle it seemed to fix it every time. Is there a sure fix for this?
I worked for Verizon before and if that's the case, have your ISP ( Internet Service Provider ) check your internet connection because sometimes your connection encounter technicalities which they called Intermittent Connection. If they told you that theres nothing wrong with the connection when they run a line test, the problem is with your router itself, there's a possibility that the router needs to be reset or replaced.
Hope this will help... Your response is very much appreciated...
Jan 25, 2011 | Linksys WRT160N Wireless Router
My modem keeps dropping connection. I have called my ISP and they say everything is running just fine. It happens when i am playing counter strike source and i start lagging badly and all of the sudden my...
Intermittent connection issues are very difficult for internet service providers to trouble shoot. The first step in trouble shooing any Intermittent connection problem is to look at the chain of equipment involved in flow of data from the internet service provider to the end user. In most homes the packets enter from the main line to the modem, than from the modem to the router, and finally from the router to you computer. So that means that the issue can be caused from the following equipment: main cable line, splitter, modem, router, or the Ethernet / wireless card of the PC. The first step in trouble shooting this problem is to wait for the internet to drop off. As soon at this happens go to your modem. If the top 4 lights are not solid green then the the modem is losing it's connection to the internet. This can be cause by some thing as simple as a bad splitter in the home or some thing as complicated at an issue at the pole. If the modem drops the connection I would recommend contacting the internet service provider and demand a service call to swap the modem and check the pole. Now if when the connection drops the modem still has access than the issue is most likely with the router or PC. If more than one computer loses it's internet access than you can rule out the computer as the issue. At this point I would have to recommend bypassing your router for about 48 hours. If the issue does not return than you know the router was the source of the problem.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 29, 2010 | Arris SURFboard® SB5101 Cable Modem
The printers drop out the network when connected
Double check the IP Address info for both printers - ensuring the IP Address, Subnet Mask and Default Gateway are configured correctly. Printers should never use DHCP - so this info should be configured as a static IP.
Also, try moving the connections for the printers to different ports on the router. It is possible that the router may be going bad and the printer ports are the first to show the signs.
One final tip - power cycle the router. I have used D-Link for over 8 years and have had to power cycle their routers and hubs occasionally as they sometimes lock up. This typically affects all ports - so this is probably not the cause of your issue but power cycling the device may help resolve the issue.
May 04, 2010 | D-Link AirPlus DI-524 Wireless Router
Occasionally I cannot go online because my computer says no internet access. I unplug the router for 30 seconds, plug back in, then it is working properly. Is the router defective? I have had the router...
It could be your router is becoming intermittent, but also your ISP connection could be dropping and not resetting properly. I have this issue occasionally and it is the ISP generally dropping my connection. Only way to test is to try a known good router and see if it corrects the problem. With data speeds increasing it is getting more difficult for the ISP to provide reliable service especially over ADSL. I went 5 years without EVER resetting my ISP connection, then started having increasing difficulties with my connection in the past 3-4 years due to higher data rates being introduced.
Mar 01, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I am running to pc's on a belkin G plus MIMO 8B09CA and my 2nd pc drops the conncetion all the time while the first runs fine and both are wired in not using the wireless setting the isp is charter com...
Have you tried swapping the cable? Use the cable connecting PC1 to the router to connect PC2 to the router, and see if the problem persists. Sometimes cable issues can cause intermittent problems.
Nov 28, 2009 | Office Equipment & Supplies
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
Feb 27, 2009 | Linksys Wireless-G Broadband Router
NetGear Wireless Router - continous internet connection drops
Hi sharon,
If you  upgraded the software but still the connecitons is droping then contact the ISP (the internet service provider ), Because it is possible that they have something wrong thier side,,,THIS ISSUE IS KNOWN AS INTERMITTENT SYNC OR ROUTE,,, check the lights on your router , when the internet goes down which light changes,,,
and once you confirm that the problem is not with your ISP then you need to purchase a new router,
reply which is the ISP you are subscribing for.
Gunja :-)
Oct 25, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
