Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
No vacuum suction during normal floor cleaning operation
Hose for attachments has suction but floor vacuum doesn't work.
When in the upright position, a lever closes a door in the suction line so that the hose can be disconnected and used with attachments. When the hose is re-attached and cleaner is moved from the upright position to the floor-operating position, the lever disengages and I believe a spring is suppose to return the door to an open position.
the spring load on this door is not working properly and the door remains closed. i can see a torsion spring wrapped around the lever but apparently it either doesn't work the way i'm imagining it or something changed with the spring.
Anyone ever see this before? (this is actually a U6632-900, upright, self-propelled, whirlwind).
  • 2 more comments
  • Anonymous Feb 07, 2008
    I have little suction to almost no suction.
  • beansie201 Nov 06, 2008
    I ordered an received the replacement parts for the actuator arm assembly and valve arm rear; however I am having trouble negotiating how the spring and new parts fit in. I tried finding the schematics for my hoover wind tunnel u6637-960 without any luck. please help
  • Anonymous Nov 30, 2008
    u6637-960 the lever disengages
  • Anonymous Jan 18, 2009
    Can anyone please post a picture of this mechanism assembled. I have the exact same problem with a hoover u6637-900. I can't figure out how the spring goes. Thanks.
    President:
  • 1,673 Answers
That door is called a valve door, and it may have broken, part #38718013. Or the valve arm, rear broke, part number 38719048. The spring part # is 38358001. Usually it is the valve arm that breaks. You would have to take the top cover off, then you can see the parts.
Posted on Jan 29, 2008
Why when I Pull out handle to use edging attachment, suction stops?
Make sure that the vacuum cleaner is in the fully upright position as there is a slide 'gate' thet directs suction to either the vacuum head or to the handle section depending as to which section you wish to use. In the upright position, you shoud be able to hear the vacuum at the handle where the attachments connect. If you still have vacuum at floor level, check the action of this gate. The actuating mechanism may be broken. Cheers Bob
Jul 12, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hose doesn't have suction
Hi Danny,
I am sorry to hear you are having difficulty with your DC18. I understand you have checked for obstructions, however, the problem you are describing sounds like a blockage. Please click on the appropriate link below to view step by step instructions on how to locate and remove a blockage in the wand, hose and the hose inlet. If you prefer we would also be happy to walk you through these checks over the phone. If the problem persists after the recommended trouble shooting steps have been carried out, please call us directly as your machine may need to be serviced by an authorized Dyson technician.
Link to Dyson support page US:
http://content.dyson.com/support/help.asp?article=1049&product=DC18-ALLFLOORS
Link to Dyson support page UK:
http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If you determine you need further assistance, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (US).
Best wishes,
Jessica
Dec 11, 2012 | Dyson DC18 all floors Bagless Upright...
My wind tunnelhas no suction when using the beater brush. Something is stuck. Can I fix it?
If the hose has suction in the upright position, and the floor has no suction in the normal use position, check for obstruction in the dirt path from the agitator cavity, thru the short hose, into the lower handle.
Oct 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
I have excellent suction power through the vac, but when I try to use the hose there is no suction power there. I have cleaned everything and it is definitely clean and clear. I've also used the reset...
When you use the upright Dyson, the handle has to be in the upright position for the hose to work. In this position, there should be a clear way through for the suction to the hose, and the suction for the normal sweeper should be off. This is all very mechanical, not electronic, and if it does not work there is either a blockage in a bit you haven't found, or a broken plasic component which should be obvious if you take out all the bits in the pipe run that can be removed - there are quite a few of them!
Hope this helps
Richard
Jul 30, 2009 | Sharper Image Dyson Slim DC18 All Floors...
Vacuum won't **** in upright position, but there is suction from the hose in the upright position
theres a knob that switches it from floors to carpet turn the to floors.please leave feedback
May 03, 2009 | Vacuums
Only suction to attachments
Something is stuck in the throat of the floor head, between the brushes that turn, and where the hose connects at one side (usually right hand side) of the floor head.
Reply back what you find.
Feb 04, 2009 | Kenmore 35912 / 35913 Progressive Upright...
No suction in the hose
see my answer to the "suction out of the handle but not to the floor" this will answer it.
Jan 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Jun 04, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
483 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
