Question about Dryers
Kenmore dryer I have kenmore dryer model number 110.64672400 and the belt that goes over the drum and pulley broke i need to replace the belt however i cant find the belt and i am not sure of the right size and where to get one. I have searched and nobody has been able to help me find the part number for this model. I know what the standard belt is but I do not want to go buy one if it is not gonna be the right size I live 60 miles from the store and I need specifics for this belt to assure the right size.
  • 2 more comments
  • ALLISON HARRISON Jan 27, 2008
  • garretdavis May 12, 2009
    except my belt didn't break it came off and i can't figure out how to get it back on
    but can't figur out how to get the belton, it seems to have alot of slack
  • 240 Answers
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Posted on Jan 27, 2008
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Kenmore 70 Series Dryer Belt Keeps Breaking
A few things to check. Make sure that the idler pulley is turning freely without any signs of distress from the bearings. Make sure that when the belt is installed that all drum, motor and pulleys are perfectly in line. Even a small amount of misalignment will cause premature failure. Turn the drum by hand and make sure is turns fairly freely. There will be some drag from the drum supports, but it should turn readily with one hand, if it is any stiffer then the drum supports may be badly worn and will need to be replaced. Make sure that the pulleys on the motor and idler are in good condition and not damaging the belt. There are basically only three main reason for a premature failure, misalignment, pulley damage and overloading. It has to be pone of those.
Nov 26, 2017 | Kenmore Whirlpool Maytag Dryer Belt...
Dryer belt keeps breaking
Did you check the idler pulley to be sure it wasn't damaged in some way, like a break in the plastic wheel or metal causing it to cut away at the belt until it breaks
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Kenmore Dryers
The dryer belt broke. I bought what I thought was the replacement belt but it is too large to fit the drum and tensioner pulley. Upon inspecting the motor, the shaft has a grooved portion around which...
You did not provide the model of your kenmore dryer so i can't provide the correct part # HOWEVER
you can go here:
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
and enter your model number and get exploded views of your machine, part numbers and the ability to order them directly from Sears
Feb 05, 2011 | Kenmore Dryers
Pulley fell off while reassembling kenmore dryer 80 series
the pulley goes right beside the motor pulley,the belt goes under the big pulley and onto the motor pulley-mike
Mar 03, 2009 | Kenmore 659 Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Drum belt assembly
take the belt and put it around the drum with the grooves touching the drum, then push a loop of the belt thru the idler pulley bracket and hook it onto the motor pulley. then the idler pulley and bracket will cause tension on the belt. if you need to see a picture then search your model number on google and it should show you a picture of how the belt goes around the motor.
by the way you dont have a good model number, or it is too new to be in most web sites.
Jan 22, 2009 | Kenmore 72802 Gas Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Dryers Logo
281 people viewed this question
Top Dryers Experts
Marvin
Marvin
