1997 Mercury Mountaineer Logo
Posted on Dec 27, 2009
How to get fan off water pump - 1997 Mercury Mountaineer
rwpfn
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Sep 03, 2010
rwpfn
Contributor
Level 1:
New Friend:
Answers
12
Questions
5
Helped
1512
Points
19
Go to auto store and rent a speacial tool for removing the large nut on the back side of the fan. the threads are lefty-tighty and righty-loosey. leave belt on to help hold fan.
1helpful
Leaking antifreeze from the fan pully. is the fan pully the water pump
The water pump will be directly behind the fan pulley. The fan pulley mounts onto the water pump shaft. So no the fan pulley is not the water pump.
Safe Journey's,
Wayne
2helpful
3answers
How do you replace water pump?
Assuming this is a 460 Ford Big Block:
REMOVAL
-Drain cooling system.
-Remove drive belts.
-Remove bolts attaching fan shroud to radiator.
-Remove fan blade from fan clutch and remove fan shroud.
-Remove fan clutch and water pump pulley from water pump.
-Remove four bolts and one nut attaching A/C compressor mounting bracket to cylinder head and water pump. Do not remove A/C compressor or power steering pump from A/C compressor mounting bracket.
-Pull A/C compressor mounting bracket forward to remove from stud on water pump.
-Remove bolt attaching generator adjusting arm to water pump. Remove four bolts attaching generator mounting bracket to cylinder head, cylinder block and water pump.
-Remove remaining water pump attaching bolts and remove water pump from engine front cover.
-Remove water pump cover from water pump. Discard water pump housing gasket and water pump cover gasket.
INSTALLATION
-Remove any gasket material from water pump cylinder front cover and separator plate mating surfaces.
-Position new water pump housing gasket and water pump cover gasket coated on both sides with Perfect Seal Sealing Compound B5A-19554-A or equivalent water-resistant sealer meeting Ford specification ESE-M4G115-A.
-Position water pump and water pump cover onto engine front cover. Install bolts and tighten to16-24 Nm (12-18 ft. lbs.).
-Install generator mounting bracket to cylinder head, cylinder block and water pump with four attaching bolts. Install generator adjusting arm to water pump with one attaching bolt. Tighten 7/16-inch bolts to 54-71 Nm (40-53 ft. lbs.) and 3/8-inch bolts to 41-54 Nm (30-40 ft. lbs.).
-Position A/C compressor mounting bracket over water pump stud and secure to cylinder head with four bolts tightened to 54-71 Nm (40-53 ft. lbs.) and secure nut to water pump to 41-54 Nm (30-40 ft. lbs.).
-Install water pump pulley and fan clutch to water pump hub with four bolts. Install fan blade to fan clutch with four bolts. Tighten water pump pulley, fan clutch hub bolts, and fan-to-fan clutch hub bolts to 16-24 Nm (12-18 ft. lbs.). Install fan shroud.
-Install drive belts.
-Fill and bleed the cooling system.
-Start the engine and check for leaks
Replacing water pump
This is for the 3.9 v6 you did not specify motor size.
Hope this helps, it it does please leave feedback Thank You and Good Luck
The water pump can be removed and installed without discharging the air conditioning system (if equipped).
  1. Disconnect battery negative cable.
  2. Drain cooling system.
  3. Do not waste reusable coolant. If solution is clean, drain coolant into a clean container for reuse.
WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094). SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS.
CAUTION: A number or letter is stamped into the tongue of constant tension clamps. If replacement is necessary, use only an original equipment clamp with matching number or letter.
  1. Remove upper radiator hose clamp and hose at radiator.
Fan Blade And Viscous Fan Drive-3.9L/5.2L/5.9L Engines 81898572
  1. The thermal viscous fan drive is attached (threaded) to the water pump hub shaft. Remove fan/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front. Threads on viscous fan drive are RIGHT HAND. A Snap-On 36 MM Fan Wrench (number SP346 from Snap-On Cummins Diesel Tool Set number 2017DSP) can be used. Place a bar or screwdriver between water pump pulley bolts to prevent pulley from rotating. Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
  2. If water pump is being replaced, do not unbolt fan blade assembly from thermal viscous fan drive.
  3. Remove fan shroud attaching hardware (two bolts at bottom-two clips at top).
  4. Remove fan shroud and fan blade/viscous fan drive assembly from vehicle as a complete unit.
  5. After removing fan blade/viscous fan drive assembly, do not place thermal viscous fan drive in horizontal position. If stored horizontally, silicone fluid in viscous fan drive could drain into its bearing assembly and contaminate lubricant.
  6. Do not remove water pump pulley bolts at this time.
Automatic Belt Tensioner Assembly-3.9L/5.2L/5.9L Engines 81898573
  1. Remove accessory drive belt as follows: The drive belt is equipped with a spring loaded automatic tensioner. Relax tension from belt by rotating tensioner clockwise (as viewed from front). When all belt tension has been relaxed, remove accessory drive belt.
  2. Remove four water pump pulley-to-water pump hub bolts and remove pulley from vehicle.
  3. Remove lower radiator hose clamp and remove lower hose at water pump.
  4. Remove heater hose clamp and heater hose from heater hose coolant return tube.
Coolant Return Tube-3.9L/5.2L/5.9L Engines-Typical 81898574
  1. Loosen heater hose coolant return tube mounting bolt and remove tube from water pump. Discard the old tube O-ring.
Water Pump Bolts-3.9L/5.2L/5.9L Engines 81898575
  1. Remove seven water pump mounting bolts.
  2. Loosen clamp at water pump end of bypass hose. Slip bypass hose from water pump while removing pump from vehicle. Discard old gasket.
CAUTION: Do not pry water pump at timing chain case/cover. The machined surfaces may be damaged resulting in leaks.
Belt Routing-3.9L/5.2L/5.9L Engines 81898576
2helpful
How do i change a water pump on 1996 grand cherokee limited V8
I'll assume you have a 4.0l
The 4.0L engine is equipped with a reverse rotation (counterclockwise) water pump. The word REVERSE is stamped or imprinted on the cover of the viscous fan drive and on the inner side of t he fan. The letter R is stamped onto the water pump impeller. When replacing water pump, ensure proper pump is installed. Installation of the wrong water pump will cause engine overheating.
NOTE:On models with 4.0 L engine, front grill must be removed to access radiator draincock. Draining cooling system can be accomplished by removing drain plug from side of block as well as by loosening radiator draincock. Drain plug is located on lower left side of engine block.
Disconnect negative battery cable. Drain cooling system. Disconnect electric cooling fan connector. Remove electric cooling fan and electric fan shroud assembly (if equipped).
Loosen, but do not remove, 4 water pump pulley-to-water pump hub bolts and 4 viscous fan-to-idler pulley nuts. Remove accessory drive belt. Remove 4 viscous fan to idler pulley nuts, and remove fan and shroud together.
Remove 4 water pump pulley bolts and remove pulley. Remove power steering pump and bracket. Disconnect heater hoses and lower radiator hose at water pump. Remove 4 water pump retaining bolts. Remove water pump.
to install just reverse procedures
2helpful
2006 dodge dakota water pump replacement instructions 3.7L
  2. Drain cooling system. Refer to Draining and Filling found under Cooling System, Service and Repair.
  3. Do not waste reusable coolant. If solution is clean, drain coolant into a clean container for reuse. WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094). SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS. CAUTION: A number or letter is stamped into the tongue of constant tension clamps. If replacement is necessary, use only an original equipment clamp with matching number or letter.
  4. Remove upper radiator hose clamp and hose at radiator.
  5. The thermal viscous fan drive is attached (threaded) to the water pump hub shaft. Remove fan/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front. Threads on viscous fan drive are RIGHT HAND. A Snap-On 36 MM Fan Wrench (number SP346 from Snap-On Cummins Diesel Tool Set number 2017DSP) can be used. Place a bar or screwdriver between water pump pulley bolts to prevent pulley from rotating. Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
  6. 6. If water pump is being replaced, do not unbolt fan blade assembly from thermal viscous fan drive.
  7. Remove fan shroud attaching hardware (two bolts at bottom-two clips at top).
  8. Remove fan shroud and fan blade/viscous fan drive assembly from vehicle as a complete unit.
  9. After removing fan blade/viscous fan drive assembly, do not place thermal viscous fan drive in horizontal position. If stored horizontally, silicone fluid in viscous fan drive could drain into its bearing assembly and contaminate lubricant.
  10. Do not remove water pump pulley bolts at this time.
  11. Remove accessory drive belt as follows: The drive belt is equipped with a spring loaded automatic tensioner. Relax tension from belt by rotating tensioner clockwise (as viewed from front). When all belt tension has been relaxed, remove accessory drive belt.
  12. 12. Remove four water pump pulley-to-water pump hub bolts and remove pulley from vehicle.
  13. Remove lower radiator hose clamp and remove lower hose at water pump.
  14. Remove heater hose clamp and heater hose from heater hose coolant return tube.
  15. Loosen heater hose coolant return tube mounting bolt and remove tube from water pump. Discard the old tube O-ring.
  16. Remove seven water pump mounting bolts.
  17. Loosen clamp at water pump end of bypass hose. Slip bypass hose from water pump while removing pump from vehicle. Discard old gasket. CAUTION: Do not pry water pump at timing chain case/cover. The machined surfaces may be damaged resulting in leaks.
INSTALLATION
  1. Clean gasket mating surfaces.
  2. Using a new gasket, install water pump to engine as follows: Guide water pump nipple into bypass hose as pump is being installed. Install water pump bolts. Tighten water pump mounting bolts to 40 Nm (30 ft. lbs.) torque.
  3. Position bypass hose clamp to bypass hose.
  4. Spin water pump to be sure that pump impeller does not rub against timing chain case/cover.
  5. Install a new O-ring to the heater hose coolant return tube. Coat the new O-ring with antifreeze before installation.
  6. Install coolant return tube and its mounting bolt to engine. Be sure the slot in tube bracket is bottomed to mounting bolt. This will properly position return tube.
  7. Connect radiator lower hose to water pump.
  8. Connect heater hose and hose clamp to coolant return tube.
  9. Install water pump pulley. Tighten bolts to 27 Nm (20 ft. lbs.) torque. Place a bar or screwdriver between water pump pulley bolts to prevent pulley from rotating.
  10. Relax tension from belt tensioner. Install accessory drive belt.
  11. CAUTION: When installing the serpentine accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to Illustration above for correct belt routing. The correct belt with correct length must be used.
  12. Position fan shroud and fan blade/viscous fan drive assembly to vehicle as a complete unit.
  13. Install fan shroud.
  14. Install fan blade/viscous fan drive assembly to water pump shaft.
  15. Fill cooling system.
  16. Connect battery negative cable.
  17. Start and warm the engine. Check for leaks.
3helpful
I need directions to change my water pump
drain engine coolant.relieve belt tension .and remove the drive belt.remove upper fan shroud.remove fan or fan and clutch assembly.remove water pump pulley and coolant hoses from water pump.remove water pump bolts.then remove pump from engine.pay attention to bolts location because they are different lenghts.clean water pump gasket mounting surface dont scratch .or pump gasket wont seal and leak .apply sealant to water pump bolts.install water pump with new gasket.if gasket paper put a sealant on it.torque water pump bolts to 30 ft lbs.if you got a 2.2L engine torque water pump bolts to 18 ft lbs.install coolant hoses on pump .install water pump pulley.install fan and fan clutch assembly.install the drive belt .and the upper fan shroud.fill the radiator with coolant.then run engine to check for leaks.WARNING AS A SAFETY PRECAUTION REMOVE NEGATIVE BATTERY CABLE SO CAR WONT BE CRANK BY ACCIDENT. ALSOOOO DONT FORGET TO TURN OFF RADIO FIRST BEFORE DISCONNECTING BATTERY SO YOU WONT LOSE YOUR RADIO CODE.
How do you take fan off to get to water pump
A special fan tool is required to remove the fan from the water pump. Yes it does unscrew. One part of the tool holds the bolts of the pulley while the other part unscrews the large nut on the water pump. Tool rental is available at some auto parts stores.
5helpful
Water pump
Please RATE ME
This IS EXACT Procedure Bu The BOOK
REMOVAL
  1. Drain cooling system.
  2. Loosen fan clutch attaching bolts.
  3. Remove fan shroud attaching bolts and remove shroud and fan.
  4. Remove drive belt.
  5. Disconnect lower radiator hose, heater hose and bypass hose from water pump.
  6. Remove fan, spacer, water pump pulley and fan shroud.
  7. Remove A/C compressor/power steering pump bracket and accessories to clear water pump stud bolt.
  8. Remove water pump attaching bolts and the water pump.
INSTALLATION
  1. Reverse procedure to install. Tighten water pump retaining bolts to 12-18 ft. lbs.
NOTE: All water pumps have a sealed bearing integral with the water pump shaft. The bearing requires no lubrication. A bleed hole in the pump housing allows water that may leak past the seal to be thrown out by the slinger. This is not a lubrication hole. If the pump is damaged and requires repair, replace it with a new pump or a rebuilt one.
I Need your Help Also !! PLEASE RATE ME
3helpful
Changing the water pump on 2000 Jeep Grand Cherokee V6
WATER PUMP
The water pump is bolted directly to the engine timing chain case/cover.
A gasket is used as a seal between the water pump and timing chain case/cover.
If water pump is replaced because of bearing/shaft damage, or leaking shaft seal, the mechanical cooling fan assembly should also be inspected. Inspect for fatigue cracks, loose blades, or loose rivets that could have resulted from excessive vibration. Replace fan if any of these conditions are found. Also check condition of the thermal viscous fan drive. Refer to Viscous Fan Drive in this group.
The water pump can be removed without discharging the air conditioning system (if equipped)
REMOVAL
Disconnect negative battery cable from battery.
Drain cooling system. Refer to Draining Cooling System in this group.
The thermal viscous fan drive is attached (threaded) to the water pump hub shaft. Remove fan/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front. Threads on viscous fan drive are RIGHT HAND. Using special tool spanner wrench 6958 with adapter pins 8346 and a suitable fan wrench loosen the fan drive Viscous Fan and Fan Drive Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094) SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS.
Remove two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware Do not attempt to remove fan shroud at this time.
Remove accessory drive belt as follows: The drive belt is equipped with a spring loaded automatic belt tensioner. Relax tension from belt by rotating tensioner clockwise (as viewed from front) Automatic Belt Tensioner - When all belt tension has been relaxed, remove accessory drive belt.
Remove seven water pump mounting bolts and one stud bolt
Remove water pump and gasket. Discard gasket.
INSTALLATION
Using a new gasket, position water pump and install mounting bolts as shown. Water Pump Installation - Tighten water pump mounting bolts to 54 N·m (40 ft. lbs.) torque.
Relax tension from belt tensioner Automatic Belt Tensioner - Install drive belt
CAUTION: When installing the serpentine accessory drive belt, belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to Belt Routing for correct belt routing. Or, refer to the Belt Routing Label located in the engine compartment. The correct belt with correct length must be used.
Be sure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
Install two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware
Be sure of at least 25 mm (1.0 inches) between tips of fan blades and fan shroud.
Fill cooling system. Refer to Refilling the Cooling System in this group.
Connect negative battery cable.
2answers
Change water pump
If you have any questions feel free to ask. Let me know if you dont get diagrams(happens sometimes)
0900c1528004319d.jpgReverse rotation water pump—2.5L and 4.0L engines
  1. Before servicing the vehicle, refer to the precautions in the beginning of this manual.
  2. Drain the cooling system.
  3. Remove or disconnect the following: NOTESome 4.0L engines are equipped with a fan clutch that threads Directly on to the water pump shaft. This fan clutch is equipped with right-hand threads. NOTEDo not store the fan clutch assembly horizontally, silicone may leak into the bearing grease and cause contamination. NOTEOne of the water pump bolts is longer than the others. Note the location for reassembly.
    • Negative battery cable
    • Electric cooling fan connector
    • Accessory drive belt
    • Engine cooling fan and pulley
    • Water pump pulley
    • Power steering pump
    • Lower radiator hose from the water pump
    • Heater hose
    • Water pump and discard the gasket
To install:
  1. Clean the mating surfaces of all gasket material.
  2. Install or connect the following:
    • Water pump using a new gasket. Torque the bolts to 17 ft. lbs. (23 Nm).
    • Heater hose
    • Water pump pulley. Torque the bolts to 20 ft. lbs. (27 Nm).
    • Engine cooling fan and shroud. Torque the bolts to 31 inch lbs. (3 Nm).
  3. Fill and bleed the cooling system.
  4. Start the engine, check for leaks and repair if necessary.
3.7L Engine
    • Fan and clutch assembly from the pump
    • Fan shroud and fan assembly. If you’re reusing the fan clutch, keep it upright to avoid silicone fluid loss!
    • Lower hose
    • Water pump (8 bolts)
  4. Installation is the reverse of removal. Tighten the bolts, in sequence, to 40 ft. lbs. (54 Nm). 0900c1528004319e.jpgWater pump tightening sequence—3.7L
Top Mercury Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mercury Expert? Answer questions, earn points and help others
