Question about PDAs
Molex ribbon Cable for Palm Pilot Zire 71
How can I obtain a new Molex ribbon Cable for Palm Pilot Zire 71?
  • 3 Answers
SOURCE: Zire 72 Molex ribbon cable
Posted on Oct 02, 2008
0 characters
1 Points
Import photos from zire 71 to windows vista 32 bit
Check and see if you can download a "mediaimpressions" driver. I have found it is great for downloading photos from any device. GOOD LUCK
Jul 02, 2012 | Palm Zire 71 Handheld
Forgot password to hot sync palm zire 71
You can create a new profile and set your options again. It's more work but it will solve the problem.
Side note: I use a great program called eWallet from iliumsoft that supports Palm, iPhone, Windows Mobile, and more to store passwords in. Works great.
Sep 09, 2009 | Palm Zire 71 Handheld
House burned down kost ny palm zire 71 software cd need a new one
I don't know any actual stores, I'm sure it's on newegg, ebay, or any electronics website.
Jun 12, 2009 | Palm Zire 71 Handheld
Palm zire 71
Install Documents to go software...a version comes with the intial CD. It can also be purchased on line through best software for reading officefiles on a PDA
May 27, 2009 | Palm Zire 71 Handheld
Palm zire 71 replaced battery camera and charging port not wrking
Dis you see if either the brown plastic locking part of the connector is broken or missing?
Do you know if the soldering joints and terminals of such connector are in good shape?
I am asking because it may be only that the flat ribbon cable is nort placed properly, or such flat ribbon cable is damaged.
Also, the connector at the mainboard can be damaged.
Depending of what is damaged, it will be the cost to repair it.
I do recoomend you to disassembly very carefully your pda again, and check such areas and parts.
If you find something that is broken, you can get the needed parts from a broken PDA in Ebay or similar sites.
Best regards,
Dec 22, 2008 | Palm Zire 71 Handheld
Sep 14, 2008 | Palm TX Handheld
All of the instructions (there are a few different ones, getting started, user guide, etc) can be viewed / downloaded here, directly from Palm:,kb=PalmSupportKB,CASE=obj(20198),ts=Palm_External2001#zire71
Apr 08, 2008 | Palm Zire 71 Handheld
My palm zire 71 does not ever synchronise to mi laptop
You can check in PalmOne web site the user manual for such PDA.
There are all the instructions in how a synchorinzation is done, and how to add new applications to it.
Best regards,
Jan 20, 2008 | Palm Zire 71 Handheld
Why doen't my Palm Zire 71 have hardset area
Check out the picture at the following link:
Aug 14, 2006 | Palm Zire 71 Handheld
PDAs Logo
143 people viewed this question
Top PDAs Experts
Are you a PDA Expert? Answer questions, earn points and help others
