Question about Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ)
Ice maker not shutting off
When we get ice out of the door the ice maker keeps shooting ice outand doesn't shut off. Sometimes it doesn;t come down the shoot but when you open the door it all falls on the floor. Help
    Novelist:
  • 87 Answers
The icemaker should have a bar that is normally in the downward position (ie 4'Oclock) when the bin is not full. The ice falls into the collector and pushes that bar into a horizontal position (ie 3'OClock). These instructions are normally on the ice dispenser section. If the bar is not being pushed up then the icemaker does not know to stop. My only suggestion would be to empty completely the ice maker bin and check that the bar can be pushed from one position to the other. If this happens then try turning on again. I hope this is of some if not much help and good luck.
Posted on Feb 08, 2008
THE ICE MAKER PRODUCES LOTS OF ICE HOWEVER WHEN I PUSH TO DISPENSE ,ICE COMES DOWN THE SHOOT BUT DOOR WILL NOT OPEN TO RELEASE.tHE WATER FEATURE WORKS FINE ON THE FRIDGE .i HAVE REPLACED THE DOOR SEAL BUT...
There is a small motor on the outside of the freezer that you can see if you look up inside the door opening for the water and ice. It may be a silver color and is not very big. On a Whirlpool it is between the ice chute and the water outlet. Also, sometimes the ice chute door freezes shut.
Mar 25, 2015 | Maytag Refrigerators
Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Sep 06, 2012 | General Electric GSH22JSXSS Stainless...
The ice maker has stopped making ice. The red light is flashing (in the freezer. Part ot technician?
Hi, The blinking red light is just a sensor that shuts down the ice maker when the door is open so that it will not dump. This should have no effect on why the ice maker is not working unless the little door that blocks the beam does not return when the door is shut again...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 02, 2010 | Whirlpool Refrigerators
Doesn bring water to ice maker
If you have water at the door, the most likely problem is that the metal bar that shuts the ice maker off has been moved to the off position. Check to see if the metal bar is in the up or down position. If it is up, move it down and vice versa and give it an hour to see if it begins making ice again.
May 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Model ED25DQXXN side by side with ice maker running.
either lift the arm up and this should stop it or u can unhook the plug for the icemaker thats about ur only 2 ptions
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
The shoot for the ice make keeps on freezing up so it doest make ice also the water doesnt come out on the door.
Replace the water valve on the back of the ref.. The solenoid is not allowing the valve to entirely shut off and you have a small leak that accumulates as a block of ice in your fill tube.
May 02, 2009 | Whirlpool ES5FHAXS Side by Side...
Icemaker won't stop making ice
there should be a saftey shut off bar or something in there to shut the ice maker down, look inside and see if there is a bar, or holes where a bar should be installed, if there is a bar, the the auto shut feature is not working you will need to replace it if thats the case, best of luck, hope that helped
Jan 18, 2009 | LG LFX25960ST Stainless Steel French Door...
Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ) Logo
122 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
