Akai PT4298HD Rear Projection Television Logo
Posted on Jan 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Akai tv 42"akai tv model pt4250a all power shut down there waas a burning smell before suutdown
seerads
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 77 Answers
  • Posted on Mar 24, 2008
seerads
Expert
Level 2:
Night Owl:
Answers
77
Questions
0
Helped
21427
Points
157
FRIED CAPS IF YOU HAVE THE TEK NOW HOW HAVE FUN IF NOT I WOULD RECOMMEND HAVING THE PRO'S HANDEL IT
Tv has picture but no sound
Check its speaker. If it is found OK, check and replace audio output board.
Picture and no sound on tv
Speaker or audio output board is faulty.
1helpful
What is the value of a resistor, location is RY801S. It is on the convergence board with a flyback. Akai projection TV model# PT4250A, thanks for listening!
I have a 50" Samsung DLP Rear-Projection HDTV that has the RY801S location number on my Power Board. The Power schematic shows a resistor with value 8.2M@1/2W
1helpful
2answers
Burning and fan type sound
That is probably the power section about to fail. The burning smell is going to be from overheating components. You will have to take it into either an akai repair depot or a local tv repair and have it looked at. Get an estimate first. The repair cost on this could be cheap if itis obvious and the repair gys are on the ball or it can be pricey if they just replace major parts (typical). Also have a good idea of what replacement cost is so you know if it is worth fixing.
1helpful
Screen distorted and burning smell
Those dead resistors that the cause,u are smelling burning plastics.Try website Tvrepairworld.com to buy a whole convergence board for the replacement.The Samsung/Akai are using the same convergence board.
1helpful
Burning smell and picture is distorted.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
NO DIGITAL TV SINGAL, WITH ANTENNA
You will need to connect to a satellite or cable provider that will give you a signal box and remote to pick up digital signals and your favorite tv stations. Everything is turning digital.
I just replace convergence board on my akai tv and
There is a burnt capacitor somewhere in the unit. Look for any burnt or swelled up capacitors. You can also usually locate a bad cap if there is burn marks on the system board. Also test power supply with voltmmeter to make sure it is a constant volt reading.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
