Sound varies This is a 3400 monitor series integrated amp. Upon starting cold, the sound fades in + out till it warms up. It has been doing this for a long time. I sure would like to find a solution. I originally bought this unit used and it did the same thing. So, the store gave me a new one. This one started some months later.
  • 152 Answers
This usually happens due to aging of the components of the amp.... the bias isnt stable and i dont think external compensation of this effect is possible...
Posted on Jan 31, 2008
05 Bonneville sle wont idle till warn
Sounds like the M.A.F. sensor. It monitors the air temp before it goes into the engine like example, if its cold out,it tell the p.c.m to adjust the air,fuel mixture because it need a little more gas to start and run a cold engine compared to it be 80 degrees out and the engine needing less gas to run. I try to explain it the best way that I can but it sounds like to me you have a bad MAF sensor.the usually located in the breather box by the air filter or in the inlet tube before it goes into the intake. Good luck,stay safe and keep us posted!
Dec 26, 2015 | Cars & Trucks
Chevy 3400
Still sounds like the starter. Did it do this before the new starter?
Jan 17, 2018 | Cars & Trucks
We have a '03 Pontiac Grand Am GT, 3.4L (3400).
If the resistor bypass doesn't solve it, another remedy could be a plug-in type engine block heater- I mean plug into household current. It keeps the engine coolant warm in the block. Every other car here in Montana uses one-works great for those below zero nights. When the wife pulls into work, just run an extension line and keep the car plugged in till time to go. Other than that, IDK, sounds like you've covered it pretty well as far as solutions.
Nov 05, 2012 | Cars & Trucks
Start driving will not shift till i reach a higher rpm then i have to back off the throttle till it drops into gear the i have to ease the throttle up for the next gear change.
Sounds like trans filter is starting clog up. Sometimes cold, fluid needs to warm up and expand. Depending on last time you did it, trans fluid & filter change is in order.
Jan 02, 2011 | Ford Explorer Cars & Trucks
1982 volvo fuel problem
sounds like a weak fuel pump or clogged fuel filter to me.
Apr 22, 2010 | 1982 Volvo 240 Series
Taking 5 min to warm up
if the monitors tub is old or cold its take sevaral minutes to warm up
Oct 02, 2009 | LG Studioworks 700S 17" CRT Monitor
The truck starts and runs good,but when it is cold it takes alot of starting to get it going. Once it warms up it starts fine it's just from cold starts that it will not start well. Do I have a filter or a...
my first suggestion would be to top up your radiator coolant with some anti-freeze and buy some engine oil that is rated for lower temperatures
Sep 25, 2009 | 1996 GMC Sierra
2002 DODGE INTREPID 3.5L NOISE
belts need tightened or replaced
Aug 18, 2009 | 1998 Dodge Neon
37 people viewed this question
 Grubhead
Grubhead
