Question about Select Brands Concord Le Cage | 52LC5PEGG | 52" Ceiling Fan
52LC5PEGG Le cage Concord
Hi My fan is turning on and off itself. Do you have any solution?
Thanks.
  • koneru_23 Jan 29, 2008
    Thanks for the reply. I will try checking switchboard if any loose connection
    Problem Solver:
  • 14 Answers
Do you have a remote if yes get it checked if no there's a loose connection in the switch board
Posted on Jan 28, 2008
How do I take apart to clean fan part real black
Hi Sherin,
You have to remove the screw or undo the clip which locks the front half of the fan cage to the back half. Then you can split the cage open, exposing the fan. You should be able to remove the fan impellor itself either by just pulling it off or by undoing a screw. Once cleaned, reverse the order to reassemble.
Jul 26, 2015 | Dryers
GE duet electric dryer. Airflow is erratic/sputtery.
M Pandora,
The squirrel cage fan would not have any bearings. When you turned the fan and you said it did not turn freely, you may have also been turning the entire drum because you would have been turning the motor shaft which then turns the belt and pulley. Not necessarily a bad thing. When you shut the dryer off, does it make a rattling noise as it comes to a stop? If it does, you may have a stripped hub in the center of your fan, and it will need to be replaced. Another way you can tell if it might be stripped is have someone watch the drum while you turn the fan, and if the drum does not move while you are spinning the fan, the hub is stripped. Those fans have a flat spot in the hub and they can get rounded out and that can cause the symptoms that you are describing. Hope this helps!
Feb 24, 2015 | GE Dryers
Need code for Concord ceiling fans
You have this backwards. The code is stored in the remote. The receiver is located inside the fan housing. You can try removing batteries from the remote, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries (or installing new ones) and testing operation. If no results, disconnect power at the ceiling fan source, not the fan itself. Pause briefly, reconnect power and test operation.
Sep 02, 2014 | Concord Fans Dryers
I have a Concord ceiling fan, and cannot access the light bulbs to change them? Please help?
Try spraying some WD-40 around the ring of the glass & push up & back & forth until the glass loosens up (hopefully).
Aug 18, 2014 | Dryers
I have an IBM x3400 MT 7975 server that is failing to power up. When i connect the power cable the green LED comes on but when i press the power button the fans run for about 1 second and turn off and the...
Hi
Welcome to fixya
Sounds like the Power cage has the fault .Probably this case would arise if the power cage gets fault This reason is the server is not getting the proper power to start . Probably this case would arise if the power cage gets fault.
Please replace the power cage and this will solves the problem
Thanks
Jan 13, 2011 | IBM x3400 Server
The fan blades are hitting the back of the cage
Just a suggestion. Make sure the back part of the cage is securely fastened to the motor housing. Good Luck,
Wayne
May 27, 2010 | Lasko 1820 Stand (Pedestal) Fan
Running not blowing air
sounds as if fan isnt attached to motor shaft. There is a set screw on the fan cage that if it loosens the shaft will turn inside of the fan not turning the fan( also known as a squirrel cage) You need to get access to the fan motor and see first if its shaft is rotating, if it is see if the squirrel cage is turning if not the set screw located on the inner collar of the squirrel cage needs to be tightened. Thie set screw is more than likly an allen set screw.
Jul 07, 2009 | Heating & Cooling
Dryers Logo
64 people viewed this question
Top Select Brands Dryers Experts
Are you a Select Brands Dryer Expert? Answer questions, earn points and help others
